| » Ice maker water over flows |
Model Number: ED25DQXDW02 Brand: Whirlpool Age: More than 10 years
When the ice maker is being filled too much water flows into the mold. I have to catch the overflow with a bowl and it is about an extra cupful of water.
Take the cover off the front of icemaker you should see test points. Take a short wire and make a jumper wire (skin a little off each end). Using the jumper wire jump from L to V this should turn the water on. Then after a few seconds pull the wire out the water should stop right away. If the water don’t stop right away the valve is bad. If the water stops right away repeat this 5-10 times and if the water stops every time the icemaker is bad. Icemaker Repair Guide
| Display Modes | |
| Water flows into ice maker when water lever is pushed | Bmore | Refrigerator & Freezer Repair | 2 | 12-19-2009 02:41 PM |
| ice maker dumps to much water and over flows | ed.p | Refrigerator & Freezer Repair | 0 | 10-30-2009 10:52 AM |
| ice maker over flows | crashgood | Refrigerator & Freezer Repair | 1 | 03-10-2009 03:50 PM |
| water over flows | edlewis | Washer Repair | 1 | 07-23-2008 08:59 AM |
| Whirlpool LA5300XM Cold water trickles, warm water flows properly | ajaysheetal | Washer Repair | 2 | 02-14-2008 04:49 PM |
