have a bosch side by side frig with water / ice dispensor. There is water flow to the ice maker as it makes ice and the ice dispensor works, but when switching to the water dispensing mode, this does not work (I can hear a noise as if the water value is trying to open but no water appears. What part is typically required to fix this issue.
