| » Ice/water dispensor Died |
Model Number: GSL25JFPABS Brand: GE Age: 1 - 5 years
I just bought a house 2 weeks ago and it came with the refrigrator and now the Ice/Water dispensor suddenly died on me. Just before that I had no water dispensing but after holding down for about 2 min it worked and suddenly it died on me. Please HELP!! Thank you in advance. Ads By Google Related Models |
If it is not making ice or dispensing water it can be the water filter, water valve or the water supply. I would start with the water filter because it needs to be changed once a year anyways. But before I replaced the water valve I would check to see if there is good water pressure coming in from the water supply. Refrigerator repair guide
Go up to the refrigerator while its running and press the lever to get ice or water. If the compressor and both fans cut off when you do this the main board is bad. I have seen this a few times but not often. If this doesn’t happen take the cover off the hinge at the top of the freezer door and make sure the plug isn’t loose. If you still haven’t found the problem it’s either the main board or the dispenser board and it’s hard to say which one. I will say that the main board goes out more. Refrigerator repair guide
| Display Modes | |
| Water Dispensor | rlslagle | Refrigerator & Freezer Repair | 0 | 07-17-2009 06:23 PM |
| Water dispensor | JC1 | Refrigerator & Freezer Repair | 2 | 07-06-2009 06:47 AM |
| Water Dispensor | ScooterMccoy | Refrigerator & Freezer Repair | 0 | 06-22-2009 04:03 PM |
| Water Dispensor | tonyc | Refrigerator & Freezer Repair | 0 | 01-31-2009 01:50 PM |
| Water Dispensor | rco224 | Refrigerator & Freezer Repair | 1 | 06-17-2008 12:47 PM |
