I Have A Maytag Frost Free Freezer Model Mqu1556aew. In Order To Clear The Drain System I Have To Remove The Rear Evaporator Shroud. How Do I Remove This Shroud?
You should see the appropriate screws on the panel at the back, inside the freezer, that hold it on. You will probably have to remove the shelf brackets (at least the ones nearest the back), to give you enough space to pull the panel forward and out. The screws are typically 1/4 inch hex-drive.
