| » freezer not freezing fridge ok |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: GLRT184RAQ Brand: Frigidaire Age: 1 - 5 years
No frosting, or build up in freezer. Is it condenser?
It's rare if ever there's a condenser problem with the exception of a 'dirty' condenser which is all too common... If your condenser coil is plugged with dust or pet hair by all means clean it out... If you have observed the evaporator coil in the freezer to find no ice buildup then what did the evaporator coil look like? Was there any frost at all? Did it only seem to build frost partially on the coil like halfway or less? List the parts that are working, compressor, fan motor(s)... Give more info to narrow down your problem, cheers kooler
__________________
Thanks for the info. The compressor works and both fans are operating. The evaporator coils had no build up of ice, but the line right before the coils was built up. The fridge is running constantly. The freezer is 50* and the fridge is warmer???????????
More than likely this system has developed a refrigerant leak or there's a restriction in the tubing... You will need to call a certified tech to repair your fridge or replace it...
__________________
| Display Modes | |
| fridge and freezer not cooling or freezing | gunner_guy26 | Refrigerator & Freezer Repair | 5 | 07-23-2008 01:10 PM |
| Fridge not cold on top and freezer not freezing | ihavabadboy | Refrigerator & Freezer Repair | 1 | 11-27-2007 07:49 PM |
| Freezer and Fridge not cooling/freezing | moderdm | Refrigerator & Freezer Repair | 4 | 11-15-2007 09:27 AM |
| freezer cold but not freezing, Fridge is ok | USMCret. | Refrigerator & Freezer Repair | 5 | 10-27-2007 06:31 PM |
| Freezer not freezing/ fridge okay | csfinlay | Refrigerator & Freezer Repair | 1 | 09-28-2007 02:36 AM |
