The water flow to the ice maker is inadequate, but the water in the door is good. Water feed to frig is good. Believe problem is in the water inlet valve. Is there a filter or a way to clean out the inlet valve. Hoses are hard to pull off and I do not see if housing on bottom unscrews or how to find filter. Thanks
