This is a side by side fridge and freezer. The freezer works ok - no ice build up or blockages and fan turns. The fridge does not cool because the flap does not open - no blockages and there is 'live' power to the motor/solonoid which controls the flap/damper . What could be the problem? I've noticed when setting the temperatures, the freezer temperature indicator reverts to actual temperature when working but the fridge indicator continues to show selected temp. even though the actual is room temp.. Could there be a problem with the programer or the thermister?? Please help. Thank you
