Discuss
Refridg
 in
Refrigerator & Freezer Repair
After You Turn It On It Rus For 1,2,maybe 3 And Then It Stops And It Will Come
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Refridg
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 11-27-2007, 03:00 PM
chollymock chollymock is offline
Junior Member
chollymock is on a distinguished road
Default Refridg
Model Number: RT14DZXJW00   Brand: Roper   Age: 1 - 5 years
After You Turn It On It Rus For 1,2,maybe 3 And Then It Stops And It Will Come Back On In 6 Hours Or So
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-27-2007, 09:52 PM
kooler kooler is offline
Senior Expert
APP Volunteer
kooler is on a distinguished road
Default need more info
The model number you listed isn't coming up in any searches I have.. Go to the ID tag and make sure the number is posted clearly as typed on the tag.. Also try to be specific when you say 'it' runs, what runs? The compressor?, the fan motor(s)?... Remove the cover behind the fridge and observe what's working and what isn't when it is turned on... Look inside the freezer and listen for the fan blowing being mindful that some units cycle the evaporator fan off and the light on when the door is opened... Post back with more info to narrow down your problem... cheers, kooler
__________________
  #3 (permalink)
Old 11-29-2007, 11:27 AM
Junior Member
Default
the refrig and freezer work fine for a few hours and the after that you have to wait for awhile for it to come back on some times you can turn the off and cooling selection off and turn it back on and it will come back on and sometimes it wont it just has to sit for awhile
  #4 (permalink)
Old 11-30-2007, 01:16 PM
Senior Expert
APP Volunteer
Default check temp control
I did find a diagram for a RT14DKXJWOO fridge so more than likely yours is similar... The next time the fridge is not running when it should be running check for power going though the thermostat... If it's not, then replace this control (AP3996712)...
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Freezer side works but not refridg side atlanta404 Refrigerator & Freezer Repair 4 05-22-2008 05:24 PM
Refridg & Freezer Not Cooling johnboy38 Refrigerator & Freezer Repair 1 09-06-2007 06:12 PM
Refridg & Freezer Not Cooling jjjetplane Refrigerator & Freezer Repair 0 09-03-2007 07:15 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
