Discuss
Auger blade spinning on shaft
 in
Refrigerator & Freezer Repair
The metal part that actually turns the auger just spins on the shaft. I cant find a nut the same
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Auger blade spinning on shaft
  #1 (permalink)
Old 08-28-2011, 06:34 PM
Junior Member
who922 is on a distinguished road
Default Auger blade spinning on shaft
Brand: Maytag   Age: 1 - 5 years
The metal part that actually turns the auger just spins on the shaft. I cant find a nut the same size and threads to tighten down on that metal piece. So, I ordered a new one that has a nut already on it. It will screw down (reverse threads). The problem is that I can not get the old one off. I took the whole silver housing out of the freezer and I still can't get it off! I even tried to cut it off with a sawzall! There's not even any way you could get that motor off without that piece coming off. The motor is fine. Any help would be appreciated.
  #2 (permalink)
Old 08-28-2011, 06:58 PM
Junior Member
Default
Number 8 in the picture.
  #3 (permalink)
Old 08-28-2011, 08:20 PM
Junior Member
Default
I thought a picture might help. You can see how you couldn't even take the motor off without getting that blade off first. It seems like an odd setup to me.
  #4 (permalink)
Old 08-30-2011, 07:53 PM
Junior Member
Default
No ideas? I'm still stuck in the same place.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag PAV2300AWW auger not spinning mcintire4 Washer Repair 2 01-18-2012 11:04 AM
Removing yoke from auger moter shaft bigart99 Refrigerator & Freezer Repair 2 12-29-2010 05:30 AM
GE Monogram Ice Auger Blade dtaggart Refrigerator & Freezer Repair 0 04-13-2009 09:48 AM
Kenmore Series 90 Washer Auger not spinning howiey@yahoo.com Washer Repair 20 01-02-2009 07:38 PM
Plastic Blade on auger broke and caught between the ice crush blades Carrot888 Refrigerator & Freezer Repair 1 08-27-2008 02:46 PM
