| » Noisy Evap Fan |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: GSS25WGPJ WW Brand: GE Age: 1 - 5 years
I have a fan in my freezer that is making a very awful humming sound. I would like a replacement but I am not sure which one to buy. Here is the info off of the fridge. GSS25WGPJ WW DH239597 GS25WG And here is the info off of the fan. PANASONIC UDQT26GE4 9.75V DC 3.25W 197D2039P012 WRG0X1054 Z0104ZT I am also in need of the fan blades that go with this assembly. |
There are two different kind of the evaporator fan motors: one with a thermistor wired into the connecting harness and another one without a thermistor.
I'll give you part numbers for both of them and you have to find out which one is in your fridge. - The part number for the evaporator fan motor without a thermistor AP3875639 - The part number for the evaporator fan motor with a thermistor AP3191003 - The part number for the fan blade AP3884328 Gene.
__________________
Professional appliance repair services in Orange County, California. |
I had what I thought was the same problem except the fan just wasn't running. GE Model # GSS22JEMAWW which is a side by side. It had the exact same Evap Fan Motor. I replaced the Evap Fan Motor (w/o Thermistor) AP3875639 but it still doesn't run. Evidently the fan isn't getting a signal to run. I checked all of the wiring quick connects and everything seems to be OK. The compressor is running and the coil frosts slightly at the bottom. I held the door switches closed and expected to see the fan start running but no dice.
Any suggestions on what other troubleshooting I can do? What components are in the fan logic circuit? Is the logic purely Compressor On, Fan On? Hopefully I don't have to replace the entire circuit board in the back panel. |
Pros recommended to replace the main control board (#801 on the unit break down diagram) if the evaporator fan is bad.
- The part number for the main control board is AP3950129 - Here are the break down diagrams for the GE refrigerator Model GSS22JEMAWW Good luck and Happy New year. Gene.
__________________
| Display Modes | |
| ge fridge question..6 vs 4 wires into evap harness? | mpodols | Refrigerator & Freezer Repair | 1 | 11-21-2007 11:08 AM |
| noisy dryer when on | ellashoe | Dryer Repair | 1 | 10-22-2007 03:45 AM |
| Very noisy dishwasher | im2busy4this | Dishwasher Repair | 1 | 09-12-2007 03:54 AM |
| Noisy Maytag DW | Rocky Chiquera | Dishwasher Repair | 2 | 07-27-2007 07:08 AM |
| noisy freezer fan | Linda | Refrigerator & Freezer Repair | 0 | 07-24-2007 01:37 PM |
