Discuss
water not fill in icemaker
 in
Refrigerator & Freezer Repair
I do not think there are other reliable ways. You have to have a simple multimeter and they are about
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » water not fill in icemaker
  #11 (permalink)
Old 04-13-2009, 02:12 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I do not think there are other reliable ways. You have to have a simple multimeter and they are about $20 only. No one water filter lasts more than 1 year.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #12 (permalink)
Old 04-13-2009, 03:22 PM
Junior Member
ngoc101 is on a distinguished road
Default
That mean I have to change water filter and have to test like you said ?
Ok i will try ,thank so much and let you know after I do
  #13 (permalink)
Old 04-25-2009, 09:15 AM
Junior Member
Default
Hello ,
I back, I just checktest piont between N and L they are 120 v and short piont T H to run the moter , yes , I Leave the jumper in for a half of a revolution and remove and the moter still run for half more revolution then stop but water still not come out . What next I do ? How we know inlet vale work or not ,show me how to test .
Thanks for help
  #14 (permalink)
Old 04-25-2009, 03:40 PM
Hardcore DIY'er
APP Volunteer
woodchuckie is on a distinguished road
Default
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
  #15 (permalink)
Old 04-26-2009, 01:13 PM
Junior Member
Default
Thanks for reply, but the water line two diference side can't fix another line ? Inlet valve part# AP3160649 ,they have 1 small ( red ) hole and other bigger (green ) how can I swap ? and the water line is clear
  #16 (permalink)
Old 04-26-2009, 04:23 PM
Hardcore DIY'er
APP Volunteer
Default
Quote:
Being careful to not touch the wire with your bare hands, just hold them to the other connectors while someone trys the water dispenser.
  #17 (permalink)
Old 04-27-2009, 06:06 PM
Junior Member
Default
OK I swapp the wires ,then try the water dispenser and nothing happen ,no water come out to ice maker ,please advive Thank you
  #18 (permalink)
Old 04-27-2009, 06:26 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Check the water feeding tube into the ice maker. If it's not frozen then the water inlet valve is bad.
__________________
  #19 (permalink)
Old 05-04-2009, 09:36 AM
Junior Member
Default
Hi , if I order inlet valve then still not working ,I can return
  #20 (permalink)
Old 05-04-2009, 09:53 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You have to address such questions to the customer service. I do not work for Appliance Parts Pros.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Icemaker won't fill w/water BCPD199 Refrigerator & Freezer Repair 7 01-20-2010 01:06 AM
Replaced Kenmore icemaker - it won't fill with water jhlee14 Refrigerator & Freezer Repair 1 09-16-2009 04:30 PM
Need to trigger water to fill Kenmore SS Icemaker WMichelleL Refrigerator & Freezer Repair 0 07-20-2009 11:52 AM
icemaker will not fill w/water jam-air brown Refrigerator & Freezer Repair 1 01-22-2009 05:17 AM
icemaker water fill erratic dcsanf Refrigerator & Freezer Repair 0 08-25-2008 01:52 PM
