GE fridge/freezer freezer is defrosting and not freezing anymore
The freezer on my side by side has defrosted and everything thawed in it. Its been at least 24 hrs and it still has not started to cool. The fridge is running constantly. Can anyone help
Replacement parts for GE PSS25MGMAWW | AppliancePartsPros.com Feel the compressor is it running/warm? Remove the cover in the freezer and take a look at the evaporator coils. If iced over you have a defrost problem. If only frosted in the area where the freon enters the coil you have a low freon problem. If no frosting at all could be you are totally out of freon or the compressor is shot. Here is a good link http://www.applianceaid.com/refrigerator.html Check out #20 |
| All times are GMT -7. The time now is 12:36 PM. |
