I have determined the inlet valve is defective. I would appreciate the correct dual inlet valve part number. I have noted a couple of diferent numbers with notes of some compatability with diferent manufacturers. It is a side by side with water and ice on the outside of the door. Thank you.
I would use the AP3103466 valve, comes with instructions and many parts to make it fit, plus reliable compression fittings.
Thank you 'richappy' for your suggestion. I ordered and received the suggested part, AP3103466 valve. I installed today , 8-30-11, and it corrected the problem.
Very good. If the tubing ever fails, the bad line can always be cut and re-attached, unlike the others that require you to buy a new valve!
