The water hose on the back of my refrigerator that comes from the bottom of the refrigerator and goes into the ice maker came apart, when the water was turned back on and now I cannot find a hose clamp that will hold the two hose’s together. Can you help :confused:
Did it come out of a connector, or was it cut?
it came out. and i removed the one ear hose clamp and used a regular hose clamp but it leeaks. what can i do:confused: if i remove the water filler tube, what plug can i use to plug the hole:confused:
Take that clamp to your local plumbing supply house; and the hose, if possible. If it's the brand I'm thinking of, you'll have to replace it with the same. Nothing else will work.
