| » Freezer and Fridge not cooling |
Quote:
Did you check the defrost thermostat for an open or closed circuit (open circuit at room temperature, closed circuit below 35 to 40 dgrs). are you sure you have all the wires properly seated and attached, you didn't knock anything loose, etc.? You could have an issue with the defrost timer or ADC board(Adaptive Defrost Control) Depending on the model number(You forgot that), get us a model number and we can verify your defrost system, and advise you from there.
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Hi, sorry I forgot the model number. It's KTRP20KDAL 02. Best I can tell nothing came loose ... I double checked everything before I put it back together. Something is definitely wrong cause as I mentioned, I go through this process about once a month. But this is the first time it didn't go back to being cold ...
Quote:
Ok then, Thanks for the Model number and better explanation. Based on the new information, Replace the defrost timer Part number: AP2984369 located inside the refrigerator control panel. Thats the more likely issue at this point. Thanks
__________________
Quote:
Here is the defrost timer circuits and test procedures. Being an intermittent problem, I hope something shows up for you. Disconnect all wires from the timer and attach ohmmeter probes to the terminals specified in the accompanying chart. If no continuity is indicated, the timer is defective. To Test Turn Timer Knob to Check Between Terminals Timer Motor Cicuit Leave as is 1 & 3 (black to red) Defrost Circuit 1st Click 1 & 2 (black to pink) Compressor Circuit 2nd Click 1 & 4 (black to orange) You can also run Voltage checks from the timer terminals to chassis ground, if needed to verify power in and out of the timer assembly, then move the the individual components using the same method.
__________________
| Display Modes | |
| GE Fridge/Freezer Not Cooling Freezer Properly | woody1397 | Refrigerator & Freezer Repair | 1 | 02-02-2011 06:56 PM |
| started up s/s fridge. freezer working fine, but fridge is not cooling | dkusko | Refrigerator & Freezer Repair | 0 | 09-05-2010 09:40 AM |
| Replacing Fridge Fan, freezer works, fridge not cooling | dlake1 | Refrigerator & Freezer Repair | 4 | 07-22-2010 06:01 AM |
| Fridge Not Cooling And Freezer Feels Like Fridge Should | ETHANSMOMMA | Refrigerator & Freezer Repair | 1 | 06-09-2010 10:39 PM |
| fridge and freezer not cooling | gailmalo | Refrigerator & Freezer Repair | 1 | 10-03-2009 02:48 AM |
