water come's down back wall inside and gathers under bottom draws. the rest works good. What's the cause?:)
water drips down the back wall inside and accumilates under the bottom drawer's. why?
Originally Posted by: phil warzon water drips down the back wall inside and accumilates under the bottom drawer's. why? I checked the drain in the back and all is ok.
:) Originally Posted by: phil warzon I checked the drain in the back and all is ok. all other functions work good.
:cool: Originally Posted by: phil warzon water drips down the back wall inside and accumilates under the bottom drawer's. why? all other functions work good.
water drips down the back wall inside the box and ends up under the drawers at the bottom. I checked the back drain and all is ok. All other functions work good.
