The water is coming out slow out, changed the filter and purged the line for continuous 2 min and still no change. When you press the dispenser the water comes out strong for a sec and then slows down, even if you repeat it multiple times the same thing happens, water comes out strong for a sec and then slows down... Any suggestions to what could be the problem? Thanks!!
