why does my ice maker leave small white matter in the glass
Originally Posted by: kreser why does my ice maker leave small white matter in the glass Kreser, In most cases, the white particles are chemicals from the water supply. they accumulate on the inside of the water supply tube, then they start to "flake" of the tube when water flows through the system and appear in the glass. It's a common occurrence in areas that have very hard water conditions. You may want to install an "in line" water filtration system on the water supply line to the fridge. :) :) :)
