The freezer completely stopped working. We have checked all power sources and they work fine. What could the problem be?
Here are your parts includes a wiring diagram, at least 3GW1 does. Replacement parts for MFU20F3G models | AppliancePartsPros.comYour model number is missing a couple digits. When you say it "completely stopped working" I am assuming that there is no sign of life so you will have to get a meter and check the unit's wiring for continuity. |
THIS FORUM IS DEAD!!!!!!! |
