Discuss
Freezer does not want to turn off
 in
Refrigerator & Freezer Repair
Hello, I have a Frigidaire 20 cu upright that went into alarm and had started defrosting. water started running out
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Freezer does not want to turn off
  By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 08-17-2011, 10:30 AM
Junior Member
pete1949 is on a distinguished road
Default Freezer does not want to turn off
Model Number: LFFH2067DWZ2   Brand: Frigidaire   Age: 5 - 10 years
Hello, I have a Frigidaire 20 cu upright that went into alarm and had started defrosting. water started running out the front. i shut it down and let it completely drain, I started it back up and have been keeping an eye on the internal temperature. It will go down to about 0 deg but doesn't want to shut off until it goes into defrost cycle.
Looking for any help!!!
Related Models
Frigidaire LFFH21F7HWA FREEZER
Frigidaire LFFH21F7HWB FREEZER
Frigidaire LFFH21F7HWC FREEZER
Frigidaire LFFH21F7HWD FREEZER
Frigidaire LFFH21F7HWE FREEZER
Frigidaire LFFH21F7HWF FREEZER
Frigidaire LFFH21F7HWG FREEZER
Frigidaire LFFH21F7HWH FREEZER
Frigidaire LFFH21F7HWJ FREEZER
Frigidaire LFFN15M5HWA FREEZER
Frigidaire LFFN15M5HWB FREEZER
Frigidaire LFFU1153DW0 Frigidaire/freezer
Frigidaire LFFU1153DW1 Frigidaire/freezer
Frigidaire LFFU1153DW2 Frigidaire/freezer
Frigidaire LFFU1153DW3 Frigidaire/freezer
Frigidaire LFFU1424DW0 Frigidaire/freezer
Frigidaire LFFU1424DW1 Frigidaire/freezer
Frigidaire LFFU1424DW10 FREEZER
Frigidaire LFFU1424DW11 FREEZER
Frigidaire LFFU1424DW12 FREEZER
Frigidaire LFFU1424DW13 FREEZER
Frigidaire LFFU1424DW14 FREEZER
Frigidaire LFFU1424DW15 FREEZER
Frigidaire LFFU1424DW16 FREEZER
Frigidaire LFFU1424DW2 Frigidaire/freezer
Frigidaire LFFU1424DW3 Frigidaire/freezer
Frigidaire LFFU1424DW4 Frigidaire/freezer
Frigidaire LFFU1424DW5 Frigidaire/freezer
Frigidaire LFFU1424DW6 FREEZER
Frigidaire LFFU1424DW7 FREEZER
Frigidaire LFFU1424DW8 FREEZER
Frigidaire LFFU1424DW9 FREEZER
Frigidaire LFFU1465DW0 Frigidaire/freezer
Frigidaire LFFU1465DW1 Frigidaire/freezer
Frigidaire LFFU1465DW2 Frigidaire/freezer
Frigidaire LFFU1465DW3 Frigidaire/freezer
Frigidaire LFFU1465DW4 Frigidaire/freezer
Frigidaire LFFU1465DW5 Frigidaire/freezer
Frigidaire LFFU1465DW6 Frigidaire/freezer
Frigidaire LFFU1466GW0 FREEZER
Frigidaire LFFU1466GW1 FREEZER
Frigidaire LFFU1466GW2 FREEZER
Frigidaire LFFU1466GW3 FREEZER
Frigidaire LFFU14F5HWA FREEZER
Frigidaire LFFU14F5HWB FREEZER
Frigidaire LFFU14F5HWC FREEZER
Frigidaire LFFU14F5HWD FREEZER
Frigidaire LFFU14F5HWE FREEZER
Frigidaire LFFU14F5HWF FREEZER
Frigidaire LFFU14F5HWG FREEZER
Frigidaire LFFU14F5HWH FREEZER
Frigidaire LFFU14F5HWJ FREEZER
Frigidaire LFFU14F5HWK FREEZER
Frigidaire LFFU14F5HWL FREEZER
Frigidaire LFFU14F5HWM FREEZER
Frigidaire LFFU14F5HWN FREEZER
Frigidaire LFFU1765DW0 Frigidaire/freezer
Frigidaire LFFU1765DW1 Frigidaire/freezer
Frigidaire LFFU1765DW11 Frigidaire/freezer
Frigidaire LFFU1765DW12 Frigidaire/freezer
Frigidaire LFFU1765DW13 Frigidaire/freezer
Frigidaire LFFU1765DW14 Frigidaire/freezer
Frigidaire LFFU1765DW15 Frigidaire/freezer
Frigidaire LFFU1765DW16 FREEZER
Frigidaire LFFU1765DW2 Frigidaire/freezer
Frigidaire LFFU1765DW3 Frigidaire/freezer
Frigidaire LFFU1765DW4 Frigidaire/freezer
Frigidaire LFFU1765DW5 Frigidaire/freezer
Frigidaire LFFU1765DW6 Frigidaire/freezer
Frigidaire LFFU1765DW8 Frigidaire/freezer
Frigidaire LFFU1765DW9 Frigidaire/freezer
Frigidaire LFFU1766GW1 FREEZER
Frigidaire LFFU1766GW2 FREEZER
Frigidaire LFFU1766GW3 FREEZER
Frigidaire LFFU1766GW4 FREEZER
Frigidaire LFFU17F5HWA FREEZER
Frigidaire LFFU17F5HWB FREEZER
Frigidaire LFFU17F5HWC FREEZER
Frigidaire LFFU17F5HWD FREEZER
Frigidaire LFFU17F5HWE FREEZER
Frigidaire LFFU17F5HWF FREEZER
Frigidaire LFFU17F5HWG FREEZER
Frigidaire LFFU17F5HWH FREEZER
Frigidaire LFFU17F5HWJ FREEZER
Frigidaire LFFU17F5HWK FREEZER
Frigidaire LFFU17F5HWL FREEZER
Frigidaire LFFU2065DW0 Frigidaire/freezer
Frigidaire LFFU2065DW1 Frigidaire/freezer
Frigidaire LFFU2065DW10 Frigidaire/freezer
Frigidaire LFFU2065DW2 Frigidaire/freezer
Frigidaire LFFU2065DW3 Frigidaire/freezer
Frigidaire LFFU2065DW4 Frigidaire/freezer
Frigidaire LFFU2065DW5 Frigidaire/freezer
Frigidaire LFFU2065DW6 Frigidaire/freezer
Frigidaire LFFU2065DW7 Frigidaire/freezer
Frigidaire LFFU2065DW8 Frigidaire/freezer
Frigidaire LFFU2065DW9 Frigidaire/freezer
Frigidaire LFFU2067DS0 Frigidaire/freezer
Frigidaire LFGF3014LBA GAS RANGE
Frigidaire LFGF3014LBB GAS RANGE
Frigidaire LFGF3014LBC GAS RANGE
Frigidaire LFGF3014LWA GAS RANGE
Frigidaire LFGF3014LWB GAS RANGE
Frigidaire LFGF3014LWC GAS RANGE
Frigidaire LFGF3022LSA GAS RANGE
Frigidaire LFGF3022LSB GAS RANGE
Frigidaire LFGF3022LSC GAS RANGE
Frigidaire LFGF3022LSD GAS RANGE
Frigidaire LFGF3022LWA GAS RANGE
Frigidaire LFGF3022LWC GAS RANGE
Frigidaire LFGF3027LBA GAS RANGE
Frigidaire LFGF3027LBB GAS RANGE
Frigidaire LFGF3027LSA GAS RANGE
Frigidaire LFGF3027LSB GAS RANGE
Frigidaire LFGF3027LSC GAS RANGE
Frigidaire LFGF3027LWA GAS RANGE
Frigidaire LFGF3027LWB GAS RANGE
Frigidaire LFHI1826LB0 REFRIGERATOR
Frigidaire LFHI1826LM0 REFRIGERATOR
Frigidaire LFHI1826LW0 REFRIGERATOR
  #2 (permalink)
Old 08-18-2011, 05:49 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
I could not find info on a DWZ2, the following is for a DW2.
Replacement parts for FRIGIDAIRE LFFH2067DW2 Frigidaire/freezer | AppliancePartsPros.com
Here is a wiring diagram
http://manuals.frigidaire.com/prodin.../297010000.pdf
I am assuming that the evaporator/freezer fan is running.
If not that may be your problem.
Have you cleaned the condenser coils?
Remove the cover inside the freezer so you can see the evaporator coils.
If they only have frost in one area then you are probably low on freon.
This would be an expensive repair and usually it makes more sense to put those dollars towards a new unit.
Here is a link, take a look at the example pictures parts way down the page.
http://www.applianceaid.com/frig_notcold.html
__________________
  #3 (permalink)
Old 08-18-2011, 06:50 AM
Junior Member
Default
Thanks for the information and the links. The evaporator fan is running and the defrost timer is functioning properly. Appliance parts suggests the temperature control, however i m not sure it's not low on freon as the compressor was replaced 2 years ago.
Regards Pete
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
When should freezer fan turn on??? swami2806 Refrigerator & Freezer Repair 6 07-14-2011 03:23 PM
Freezer does not turn off rybelt Refrigerator & Freezer Repair 1 07-25-2010 12:34 PM
Freezer Does Not Turn Off MagnumVP Refrigerator & Freezer Repair 2 06-21-2010 05:02 PM
Freezer Fan does not always turn on Doug4717 Refrigerator & Freezer Repair 9 12-14-2009 07:52 PM
Sears chest freezer will not turn on jigs Refrigerator & Freezer Repair 2 03-22-2009 10:51 AM
