Evaporator freezes every 2 weeks. Defroster heater checks fine. Possible defrost timer? If so where located? :confused:
Here are your parts Replacement parts for AMANA ATB1935HRQ REF - TOP MOUNT | AppliancePartsPros.comDefrost timer is Item 15 in Section 5. There is usually a hole in the cover to let you rotate te timer cam. Here is my normal blurb on defrost problem troubleshooting. First remove the evaporator cover in the freezer so you can see the coils. Do not let them de-ice. If they are heavily iced/frosted over you have a defrost problem. If yes. Manually force a defrost cycle by turning the defrost timer cam till the fans and compressor turn off. Now check the defrost heater to see if it is on. Be careful you do not want to burn your fingers. If the heater is on then the timer needs replacing, re: it is probably stalling during it's rotation so is never getting into a defrost cycle. If not on. Unplug the unit. Remove the wire for one side of the heating element from the wiring and measure it for continuity, usually around 20 ohms or so. If the heater is OK Remove one wire to the defrost thermostat and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK. If both the above are OK then odds are the defrost timer contacts are toast. Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo. |
THIS FORUM IS DEAD!!!!!!! |
Denman: Thanks for your reply. Can you explain how to remove defrost timer? Is there more than 1 screw? Thank You.
Am not 100% sure but it may be only one screw and then the cover will pull forward to release some clips so you can get at the timer. The timer may then just be clipped onto the cover. |
