I Need To Fix Display Touch Disp.part Number Ap4368052. May Have Short In Wire From Dis. To Mother Board Can That Wire Be Replaced Or Do I Have To Order Foamed Dr. Please Advise.
Hello. If the broke wire is inside the door assembly, you will need to replace the foamed door. Hope this helps. Part number: AP3779004
