| » Whirlpool cant remove ice bin |
Model Number: Part No. 4322658A Brand: Whirlpool Age: 1 - 5 years
Can't remove the ice bin from the freezer door. Push on the release button and the ice bin wont come off. The augur will no longer spin to release ice. Found the Part No. 4322658A repair manual but it does not have this particular problem in it. Any help would be appreciated.
Thanks Ads By Google Related Models |
Hello rtniehaus. The ice bin may be frozen to the door. Try leaving the door open for a little while and see if the bin comes out. You can use a flashlight to look under the bin and see if you see ice build up. If so, it will need to thaw out before you can remove it. Post your model number please if you need more help. Hope this helps. Model Number Locator
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Jeff K. / APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Hello. The only other thing you can try is to get a hook shaped pick tool. Then go through the opening in the bottom of the ice bucket and manually push the rod over to release the clips from the tabs. This can be very hard to do, but is possible. Hope this helps.
__________________
I have a Whirlpool GC5SHEXNS05 and I had the same problem. It was NOT due to ice, but rust.The ice bin would not come off because the rod (part #28) was rusted in the ice bin socket. It eventually came off when I exerted extreme force upward (while pushing in the release). Then the entire rod came up with the ice bin. At this point, I am using WD40 to try to get the rod off. I likely will have to replace the rod bc the corrosion will distort it's angles and thus the Augar will not turn when a lot of ice is in the bin. I assume the rust was the result of me using water to melt the ice when I was initially trying to get the bin off. I did not complete the progect till weeks later, therefore allowing time for the rust to develop. I hope this helps! I know I feel good that it is finally off!
So I've had to use boiling water to melt frozen ice down inside the auger, but mine still works when my bin is full of ice. No matter how much upward force I use, I still can't remove that frackin ice bin...so frustrating and I'm at my wits end. It's not the end of the world, but I'd much rather remove the ice bin if it freezes over than have to pour hot water in there to thaw it until it works again. Any suggestions?
Hello bobloblaw. Depending on the model number, the release may be bad and need to be replaced on the ice bucket assembly.
__________________
You will need to thaw out the bucket to remove the bucket from the door. It may require using a pick tool to release the catch.
__________________
I have the same problem with the ice bin not releasing to remove it. Have done everything suggested, except using the hook tool (don't have one--what is it called?). Tried inserting a knife blade flat, but no luck.
I simply want to remove the auger so I can use it as an ice bucket to catch the ice from icemaker. Can't use the dispenser anyway without it getting frozen up repeatedly and since I can't get the bin off, I have to thaw everything out completely to make any headway. And the bin still will not release. What will happen if I remove the screws that are holding in (I presume) the auger - there on the inside of the bin? Would I be able to get the bin off then? I suppose the manufacturers have learned by now not to put ice dispenser mechanisms in the doors, since they tend to melt a bit when the frig "cycles" and thus clog everything up. I wish I'd had known to research everything about a newfangled frig before buying it. |
| Display Modes | |
| whirlpool cabinet remove | donshu | Washer Repair | 2 | 08-23-2010 04:01 PM |
| How to remove door of Whirlpool range | buddy0928 | Oven Repair (including Ranges and Cooktops) | 1 | 02-10-2010 04:17 PM |
| how to remove Motor from Whirlpool | tomlicnk | Dishwasher Repair | 3 | 04-04-2009 02:28 PM |
| Remove Lid from Whirlpool Elec Dryer | jamiet101 | Dryer Repair | 1 | 03-25-2009 11:20 AM |
| How to remove Whirlpool Microwave Door | kmalach | Microwave Repair | 0 | 08-29-2008 04:55 PM |
