This is a free standing clear ice cuber. The problem before was no water coming in. I replaced the water inlet valve. Now the machine seems to be running constantly with a low production of ice. The thermostat is working when I pile the ice on top of it. Then the machine will stop running for a while. I cleaned the condenser with a vacuum and also cleaned the machine with solution. There is no scale build up on the freeze plate
