I am trying to replace the overload start relay on my fridge. The original has 5 wires connected to it. The new one has two connectors marked L and N. I need some help figuring out how to wire this thing. Thanks in advance.
What is the part # of the new start device, is it a small,black plastic device?
It is a grey Embraco EECON QD TSD2
That is not a factory service part #, it is an embraco proprietary part. If you have a meter to check things, I can help you. I can only help if I know the three pin compressor wiring. The usual pinout is common on top, start winding on the bottom right, run winding on bottom left, in a triangle configuration.
