Discuss
Ice maker water splashes out of fill tube
 in
Refrigerator & Freezer Repair
I am working a problem where there is excess water coming into the freezer compartment near the ice maker. I
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Ice maker water splashes out of fill tube
  #1 (permalink)
Old 03-30-2009, 12:39 PM
Junior Member
mharrison is on a distinguished road
Default Ice maker water splashes out of fill tube
Model Number: RT21LMXKQ00   Brand: Roper   Age: 5 - 10 years
I am working a problem where there is excess water coming into the freezer compartment near the ice maker. I pulled the ice maker and found much ice around the back of the refrig below the water inlet. The white 'hopper' (P/N 22 in the ice maker diagram) was clogged with ice. Also, there was a stalactite of ice growing on the styrofoam insulation below the 'fill gutter' (can't see this on the diagram, but it is a white plastic channel (profile of a rain gutter) that fits into the body of the frig. The cold water inlet pipe is attached to it outside the frig, and water flows down this gutter into the hopper.
I have tested the water control valve - it opens and closes without a dribble. BUT, when the valve is open, some water slops over the side of the gutter, and I think that this is the root cause of my problem. I tried turning down the water flow by adjusting the manual water valve at the wall, but at 75 deg closed (90 would be fully closed) there seemed to be no reduction in pressure. Also, our water pressure is within spec.
Any ideas on why I have the splashing? Is the fill gutter replacable? I could maybe get a cover of some sort on the gutter to contain the splashing (turn into more of a pipe) ...
Thanks.
Mike
Related Models
Roper RT21LMXKQ00 REFRIGERATOR
Roper RT21LMXKQ01 TOP-MOUNT REFRIGERATOR
Roper RT21LMXKQ02 TOP-MOUNT REFRIGERATOR
Roper RT21LMXKQ03 REFRIGERATOR
Roper RT21LMXKQ04 REFRIGERATOR
Whirlpool RT21LMXKQ05 REFRIGERATOR
Roper RT21LMXKQ06 REFRIGERATOR
Whirlpool RT21LMXKQ07
Roper RT21LMXKQ08 REFRIGERATOR
Roper RT21LMXKQ09 REFRIGERATOR
Roper RT21LMXKQ10 REFRIGERATOR
Roper RT21LMXKT00 REFRIGERATOR
Roper RT21LMXKT01 TOP-MOUNT REFRIGERATOR
Roper RT21LMXKT02 TOP-MOUNT REFRIGERATOR
Roper RT21LMXKT03 REFRIGERATOR
Roper RT21LMXKT04 REFRIGERATOR
Whirlpool RT21LMXKT05 REFRIGERATOR
Roper RT21LMXKT06 REFRIGERATOR
Whirlpool RT21LMXKT07
Roper RT21LMXKT08 REFRIGERATOR
Roper RT21LMXKT09 REFRIGERATOR
Roper RT21LMXKT10 REFRIGERATOR
Roper RT21SKXJN00 REFRIGERATOR
Roper RT21SKXJW00 REFRIGERATOR
Roper RT21SKXLQ00 TOP-MOUNT REFRIGERATOR
Roper RT21SKXLQ01 TOP-MOUNT REFRIGERATOR
Roper RT21SKXLQ02 REFRIGERATOR
Roper RT22AKXBL00 REFRIGERATOR
Roper RT22AKXBW00 REFRIGERATOR
Roper RT25BKXAW00 Refrigerators*
Whirlpool RT25BKXZL01
Roper RT25BKXZW00 Refrigerators*
Roper RT25BKXZW01 Refrigerators*
Maytag RTC1500AAL REF - TOP MOUNT
Maytag RTC1500AAW REF - TOP MOUNT
Maytag RTC1500CAE REF - TOP MOUNT
Maytag RTC1500CAL REF - TOP MOUNT
Admiral RTC1500CGE REF - TOP MOUNT
Maytag RTC1500DAE REF - TOP MOUNT
Maytag RTC1500DAM REF - TOP MOUNT
Maytag RTC15A REF - TOP MOUNT
Maytag RTC1700AAL REF - TOP MOUNT
Maytag RTC1700AAW REF - TOP MOUNT
Maytag RTC1700CAE REF - TOP MOUNT
Maytag RTC1700CAL REF - TOP MOUNT
Maytag RTC1700DAE REF - TOP MOUNT
Maytag RTC1700DAM REF - TOP MOUNT
Maytag RTC17A REF - TOP MOUNT
Maytag RTC1900AAL REF - TOP MOUNT
Maytag RTC1900AAW REF - TOP MOUNT
Maytag RTC1900CAE REF - TOP MOUNT
Maytag RTC1900CAL REF - TOP MOUNT
Maytag RTC1900CAW REF - TOP MOUNT
Maytag RTC19A REF - TOP MOUNT
Admiral RTCA176AAE REF - TOP MOUNT
Admiral RTCA176AAM REF - TOP MOUNT
Admiral RTCA196AAE REF - TOP MOUNT
Admiral RTCA196AAM REF - TOP MOUNT
Admiral RTCA196BAE REF - TOP MOUNT
Admiral RTCA196BAM REF - TOP MOUNT
Admiral RTCA216AAE REF - TOP MOUNT
Admiral RTCA216AAM REF - TOP MOUNT
Admiral RTCA216BAE REF - TOP MOUNT
Admiral RTCA216BAM REF - TOP MOUNT
Maytag RTD1700AAL REF - TOP MOUNT
Maytag RTD1700AAW REF - TOP MOUNT
Maytag RTD1700CAE REF - TOP MOUNT
Maytag RTD1700CAL REF - TOP MOUNT
Maytag RTD1700CAW REF - TOP MOUNT
Maytag RTD1700CAW Ref - Top Mount
Admiral RTD1700CGE REF - TOP MOUNT
  #2 (permalink)
Old 03-30-2009, 02:09 PM
Senior Member
applianceman is on a distinguished road
Default
If the hopper you are referring to was clogged with ice you need to replace the water valve. Because what happens is that there will be a slow leak past the valve causing ice to build up in the fill tube and in the fill cup and you won’t always see the leak. You also need to clean out the fill tube (gutter) and get all the ice out of that.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Ice Maker Splashes Water Out? advocateone Refrigerator & Freezer Repair 0 10-15-2009 05:55 PM
Ice maker fill tube dripping heathk Refrigerator & Freezer Repair 10 09-24-2009 06:28 AM
ice maker fill tube frozen chip Refrigerator & Freezer Repair 1 06-15-2009 12:32 PM
Ice Maker Fill Tube? Keegan Refrigerator & Freezer Repair 1 02-13-2008 11:40 AM
ice maker fill tube freezing ricka Refrigerator & Freezer Repair 3 01-25-2008 06:07 AM
