No cold water is dispensed,no water to the ice maker. When you attempt to get water from door, water is dispensed via a 1/4" hose to the floor. We live in a hot climate and were away for 3 weeks, found this problem. The condenser (round black tank) is hot. If this is icing do I just unplug the refer?
Thanks so much!
