Discuss
Need help installing damper and control kit
 in
Refrigerator & Freezer Repair
I ordered and received the full damper and control kit for this model (AP5176342), but am having some issues getting
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Need help installing damper and control kit
  #1 (permalink)
Old 08-11-2011, 08:54 AM
Junior Member
billbarrou is on a distinguished road
Red face Need help installing damper and control kit
Model Number: FRS26F5AW6   Brand: Frigidaire   Age: 5 - 10 years
I ordered and received the full damper and control kit for this model (AP5176342), but am having some issues getting the wiring to match up correctly. I asked the experts under the part section but the only real answer was "read the instructions" which seem to have been translated from Chinese.
The issue is that the wiring harnesses don't necessarily match up with the wiring harnesses from the old part. On the kit that is being replaced, the damper motor has connections in four places... one on the bottom, a small one with a green wire near the top/side, and two at the back next to the insulation that have 3 pins which are "staggered". In the old kit there are two connectors with gray and purple wires which have staggered harnesses and fit these pins. On the new kit, there is only one staggered harness with gray and purple wires, but the damper motor still has the two sets of pins. Should this go on the "inside" set of pins (closest to the insulation) or the "outside" set of pins (closest to the front of the refrigerator)? Also there is a harness with two wires, one light blue and one orange with a white stripe, which doesn't seem to fit anywhere and does not exist in the old kit.
The answer I got from the expert was "the kit has been redesigned to work without some connections. The instruction sheet will explain this to you." Um, no it doesn't.
Related Models
Frigidaire FRS26F5AW6 Frigidaire/refrigerator
Frigidaire FRS26FCDB0 Frigidaire/refrigerator
Frigidaire FRS26FCDB3 Frigidaire/refrigerator
Frigidaire FRS26FCDB4 Frigidaire/refrigerator
Frigidaire FRS26FCDB5 Frigidaire/refrigerator
Frigidaire FRS26FCDB6 Frigidaire/refrigerator
Frigidaire FRS26FCDB7 Frigidaire/refrigerator
Frigidaire FRS26FCDQ0 Frigidaire/refrigerator
Frigidaire FRS26FCDQ3 Frigidaire/refrigerator
Frigidaire FRS26FCDQ4 Frigidaire/refrigerator
Frigidaire FRS26FCDQ5 Frigidaire/refrigerator
Frigidaire FRS26FCDW0 Frigidaire/refrigerator
Frigidaire FRS26FCDW1 Frigidaire/refrigerator
Frigidaire FRS26FCDW2 Frigidaire/refrigerator
Frigidaire FRS26FCDW3 Frigidaire/refrigerator
Frigidaire FRS26FCDW4 Frigidaire/refrigerator
Frigidaire FRS26FCDW5 Frigidaire/refrigerator
Frigidaire FRS26H5ASB0 Frigidaire/refrigerator
Frigidaire FRS26H5ASB1 Frigidaire/refrigerator
Frigidaire FRS26H5ASB3 Frigidaire/refrigerator
Frigidaire FRS26H5ASB4 Frigidaire/refrigerator
Frigidaire FRS26H5ASB5 Frigidaire/refrigerator
Frigidaire FRS26H5ASB6 Frigidaire/refrigerator
Frigidaire FRS26H5ASB7 Frigidaire/refrigerator
Frigidaire FRS26H5ASB8 Frigidaire/refrigerator
Frigidaire FRS26H5ASB9 Frigidaire/refrigerator
Frigidaire FRS26H5ASBA Frigidaire/refrigerator
Frigidaire FRS26H5DSB0 Frigidaire/refrigerator
Frigidaire FRS26H5DSB1 Frigidaire/refrigerator
Frigidaire FRS26H5DSB2 Frigidaire/refrigerator
Frigidaire FRS26H5DSB3 Frigidaire/refrigerator
Frigidaire FRS26H5DSB4 Frigidaire/refrigerator
Frigidaire FRS26H5DSB5 Frigidaire/refrigerator
Frigidaire FRS26H5DSB9 Frigidaire/refrigerator
Frigidaire FRS26H5DSBN Frigidaire/refrigerator
Frigidaire FRS26H7CB0 Frigidaire/refrigerator
Frigidaire FRS26H7CB1 Frigidaire/refrigerator
Frigidaire FRS26H7CB2 Frigidaire/refrigerator
Frigidaire FRS26H7CB3 Frigidaire/refrigerator
Frigidaire FRS26H7CB4 Frigidaire/refrigerator
Frigidaire FRS26H7CQ0 Frigidaire/refrigerator
Frigidaire FRS26H7CQ1 Frigidaire/refrigerator
Frigidaire FRS26H7CQ2 Frigidaire/refrigerator
Frigidaire FRS26H7CQ3 Frigidaire/refrigerator
Frigidaire FRS26H7CQ4 Frigidaire/refrigerator
Frigidaire FRS26H7CSB0 Frigidaire/refrigerator
Frigidaire FRS26H7CSB1 Frigidaire/refrigerator
Frigidaire FRS26H7CSB2 Frigidaire/refrigerator
Frigidaire FRS26H7CSB3 Frigidaire/refrigerator
Frigidaire FRS26H7CSB4 Frigidaire/refrigerator
Frigidaire FRS26H7CW0 Frigidaire/refrigerator
Frigidaire FRS26H7CW1 Frigidaire/refrigerator
Frigidaire FRS26H7CW2 Frigidaire/refrigerator
Frigidaire FRS26H7CW3 Frigidaire/refrigerator
Frigidaire FRS26H7CW4 Frigidaire/refrigerator
Frigidaire FRS26HBBSB0 Frigidaire/refrigerator
Frigidaire FRS26HBBSB1 Frigidaire/refrigerator
Frigidaire FRS26HBBSB2 Frigidaire/refrigerator
Frigidaire FRS26HBBSB3 Frigidaire/refrigerator
Frigidaire FRS26HF5AB0 Frigidaire/refrigerator
Frigidaire FRS26HF5AB1 Frigidaire/refrigerator
Frigidaire FRS26HF5AB2 Frigidaire/refrigerator
Frigidaire FRS26HF5AB3 Frigidaire/refrigerator
Frigidaire FRS26HF5AB4 Frigidaire/refrigerator
Frigidaire FRS26HF5AB5 Frigidaire/refrigerator
Frigidaire FRS26HF5AQ0 Frigidaire/refrigerator
Frigidaire FRS26HF5AQ1 Frigidaire/refrigerator
Frigidaire FRS26HF5AQ2 Frigidaire/refrigerator
Frigidaire FRS26HF5AQ3 Frigidaire/refrigerator
Frigidaire FRS26HF5AQ4 Frigidaire/refrigerator
Frigidaire FRS26HF5AQ5 Frigidaire/refrigerator
Frigidaire FRS26HF5AW0 Frigidaire/refrigerator
Frigidaire FRS26HF5AW1 Frigidaire/refrigerator
Frigidaire FRS26HF5AW2 Frigidaire/refrigerator
Frigidaire FRS26HF5AW3 Frigidaire/refrigerator
Frigidaire FRS26HF5AW4 Frigidaire/refrigerator
Frigidaire FRS26HF5AW5 Frigidaire/refrigerator
Frigidaire FRS26HF6BB0 Frigidaire/refrigerator
Frigidaire FRS26HF6BB1 Frigidaire/refrigerator
Frigidaire FRS26HF6BB2 Frigidaire/refrigerator
Frigidaire FRS26HF6BB3 Frigidaire/refrigerator
Frigidaire FRS26HF6BB4 Frigidaire/refrigerator
Frigidaire FRS26HF6BB6 Frigidaire/refrigerator
Frigidaire FRS26HF6BQ0 Frigidaire/refrigerator
Frigidaire FRS26HF6BQ1 Frigidaire/refrigerator
Frigidaire FRS26HF6BQ2 Frigidaire/refrigerator
Frigidaire FRS26HF6BQ3 Frigidaire/refrigerator
Frigidaire FRS26HF6BQ4 Frigidaire/refrigerator
Frigidaire FRS26HF6BQ6 Frigidaire/refrigerator
Frigidaire FRS26HF6BW0 Frigidaire/refrigerator
Frigidaire FRS26HF6BW1 Frigidaire/refrigerator
Frigidaire FRS26HF6BW2 Frigidaire/refrigerator
Frigidaire FRS26HF6BW3 Frigidaire/refrigerator
Frigidaire FRS26HF6BW4 Frigidaire/refrigerator
Frigidaire FRS26HF6BW6 Frigidaire/refrigerator
Frigidaire FRS26HF7BB0 Frigidaire/refrigerator
Frigidaire FRS26HF7BB1 Frigidaire/refrigerator
Frigidaire FRS26HF7BB2 Frigidaire/refrigerator
Frigidaire FRS26HF7BB3 Frigidaire/refrigerator
Frigidaire FRS26HF7BB4 Frigidaire/refrigerator
Frigidaire FRS26HF7BQ0 Frigidaire/refrigerator
Frigidaire FRS26HF7BQ1 Frigidaire/refrigerator
Frigidaire FRS26HF7BQ2 Frigidaire/refrigerator
Frigidaire FRS26HF7BQ3 Frigidaire/refrigerator
Frigidaire FRS26HF7BQ4 Frigidaire/refrigerator
Frigidaire FRS26HF7BW0 Frigidaire/refrigerator
Frigidaire FRS26HF7BW1 Frigidaire/refrigerator
Frigidaire FRS26HF7BW2 Frigidaire/refrigerator
Frigidaire FRS26HF7BW3 Frigidaire/refrigerator
Frigidaire FRS26HF7BW4 Frigidaire/refrigerator
Frigidaire FRS26HR4AB0 Frigidaire efrigerator
Frigidaire FRS26HR4AB1 Frigidaire efrigerator
Frigidaire FRS26HR4AB3 Frigidaire/refrigerator
Frigidaire FRS26HR4AQ0 Frigidaire efrigerator
Frigidaire FRS26HR4AQ1 Frigidaire efrigerator
Frigidaire FRS26HR4AQ3 Frigidaire/refrigerator
Frigidaire FRS26HR4AW0 Frigidaire efrigerator
Frigidaire FRS26HR4AW1 Frigidaire efrigerator
Frigidaire FRS26HR4AW3 Frigidaire/refrigerator
Frigidaire FRS26HR4DB0 Frigidaire/refrigerator
  #2 (permalink)
Old 08-16-2011, 10:24 AM
Junior Member
Default
Bumping this back to the top to try to get an answer
  #3 (permalink)
Old 10-01-2011, 09:02 PM
Junior Member
Haroldoftherock is on a distinguished road
Default Any luck in finding an answer on this one
Hi. I find myself with the same problem. Did you by any chance get an answer? Your help is really appreciated.
Harold
  #4 (permalink)
Old 10-02-2011, 03:26 PM
Junior Member
needhelp2 is on a distinguished road
Default same problem
have you received any response to your question? I have replaced the damper control box on my frigidaire because it was too warm due to damper not opening. New damper control box harnesses did not match, installed anyway, now fridge is way too cold (below 30 degrees), freezes fresh foods but freezer is @ 0 degrees
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Damper control? dchapman3850@yahoo.com Refrigerator & Freezer Repair 1 05-09-2011 05:31 AM
damper control coldpart Refrigerator & Freezer Repair 0 11-24-2010 02:30 PM
Damper Control or Other? albert a Refrigerator & Freezer Repair 0 09-27-2009 04:51 PM
Damper Control for Maytag joeba Refrigerator & Freezer Repair 6 09-14-2009 05:59 AM
Air Damper control rlewis23606 Refrigerator & Freezer Repair 1 04-07-2009 03:17 AM
