Discuss
defrost cycle not working
 in
Refrigerator & Freezer Repair
The fins in the freezer compartment are frosting up and not allowing air to circulate to the refrigerator side. How
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » defrost cycle not working
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 08-01-2007, 12:40 PM
tottalyoff tottalyoff is offline
Junior Member
tottalyoff is on a distinguished road
Default defrost cycle not working
Model Number: MSD2756AEW   Brand: Maytag   Age: 1 - 5 years
The fins in the freezer compartment are frosting up and not allowing air to circulate to the refrigerator side. How can I troubleshoot the defrost cycle?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 08-01-2007, 03:40 PM
Admin / APP Team Admin / APP Team is offline
Administrator
APP Team
Admin / APP Team has disabled reputation
Default
Hi tottalyoff,
From the Maytag manual:
ADAPTIVE DEFROST CONTROL
The adaptive defrost control assembly is a microprocesser controlled defrost timer. This new control allows defrost to occur only when needed, compared to mechanical timers which defrost at a preset interval whether it is necessary or not. The new control will continually adjust defrost intervals based on the amount of time the defrost heater is energized. This allows the defrost intervals to be adjusted closer to the optimum defrost interval based on use, thus saving energy.
HOW TO CHECK THE ADAPTIVE DEFROST CONTROL ON MAYTAG REFRIGERATORS
1. Disconnect the unit from the power source.
2. Open the fresh food door and remove any items on the top shelf.
3. Remove the light shield and the temperature control housing.
4. Connect the refrigerator to a wattmeter.
5. Make sure compressor is running (cold control closed).
6. Using an insulated number 22 jumper wire short between L1 and Test; this will
put the refrigerator into a defrost for approximately 23 minutes.
7. The watt meter should read between 500 to 600 watts depending on the
model.
Note: If the temperature control is open
(unit not running and you jumper L1 and
Test) the unit will cycle through the test
mode in two seconds and there will be no
watt draw.
Check the adaptive defrost control first and let us know what you found.
  #3 (permalink)
Old 08-01-2007, 07:05 PM
Junior Member
Default
that adaptive defrost control is kind of hidden behind a few things. it's too bad they couldn't have made access to the test points a little easier. What I think I'm going to do this monitor the temperature right by the defrost heater for a day or so. I have already melted the ice from the coils and got the thing running again trying to save the food. But, when the ice starts to form again I am gonna do that test and I will let you know. Thanks for getting back so quick and thanks for the help. How did we survive before the Internet? Take care and talk to you soon.
  #4 (permalink)
Old 10-08-2007, 12:20 PM
rallison rallison is offline
Junior Member
rallison is on a distinguished road
Default
I think I'm having the same problem and can't get to the adaptive defrost control module. Any advise on how to get to it to trigger the test point?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
defrost heater Ashman Refrigerator & Freezer Repair 0 07-31-2007 01:13 PM
defrost cycle problem blessen Refrigerator & Freezer Repair 2 07-29-2007 10:31 AM
GE Top frz defrost problem? vrocrider Refrigerator & Freezer Repair 1 07-21-2007 10:40 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
