Discuss
Freezer temperature problem, fan?
 in
Refrigerator & Freezer Repair
The problem started as no ice from the icemaker. After some investigation, it was evident that the top of this
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Freezer temperature problem, fan?
  #1 (permalink)
Old 03-29-2009, 10:16 AM
doasc doasc is offline
Junior Member
doasc is on a distinguished road
Default Freezer temperature problem, fan?
Model Number: B20CS80   Brand: Bosch   Age: 1 - 5 years
The problem started as no ice from the icemaker. After some investigation, it was evident that the top of this side-by-side Bosch was too warm to freeze ice and the bottom was maintaining sub zero temperatures. The Bosch uses sensors and a control board instead of defrost timers and thermoswitches. The sensors and defrost heater checked out. However the fan in the freezer seems to work some of the time. The service manual (act. Daewoo) shows that the fan doesn't run when defrosting or when the door is open. But doesn't specifically say if it should run otherwise. Took the 13V DC motor out and it "seemed" to run intermitantly with 12V power. Reinstalled and things seemed good for a few hours. However, the next morning the temperature issue was back.
Typically when the compressor is running the evaporator/freezer fan should running. But the fridge fan seems to always run, except when the door is open. When should both the freezer and fridge fan run?
Related Models
Frigidaire B30LSPSC0 Frg(v0) / Upright Freezer
Frigidaire B30LSPSC1 Frg(v0) / Freezer
Magic Chef B31FA-2KW Range - F/s Std Gas
Magic Chef B31FA-2KX-DD Range - F/s Std Gas
Magic Chef B31FA-2KX-ON Range - F/s Std Gas
Magic Chef B31FA-2W Range - F/s Std Gas
Magic Chef B31FA-2X-DD Range - F/s Std Gas
Magic Chef B31FA-2X-ON Range - F/s Std Gas
Magic Chef B31FA-3KW Range - F/s Std Gas
Magic Chef B31FA-3KX-ON Range - F/s Std Gas
Magic Chef B31FA-3W Range - F/s Std Gas
Magic Chef B31FA-3X-ON Range - F/s Std Gas
Magic Chef B31FA-7 Range - F/s Std Gas
Magic Chef B31FA-7W Range - F/s Std Gas
Magic Chef B31FA-7X-ON Range - F/s Std Gas
Magic Chef B31FA-92W Range - F/s Std Gas
Magic Chef B31FA-92X-DD Range - F/s Std Gas
Magic Chef B31FA-92X-ON Range - F/s Std Gas
Magic Chef B31FK-2KW Range - F/s Std Gas
Magic Chef B31FK-2KX-DD Range - F/s Std Gas
Magic Chef B31FK-2KX-ON Range - F/s Std Gas
Magic Chef B31FK-2W Range - F/s Std Gas
Magic Chef B31FK-2X-DD Range - F/s Std Gas
Magic Chef B31FK-2X-ON Range - F/s Std Gas
Magic Chef B31FK-3KW Range - F/s Std Gas
Magic Chef B31FK-3KX-ON Range - F/s Std Gas
Magic Chef B31FK-7 Range - F/s Std Gas
Magic Chef B31FK-7W Range - F/s Std Gas
Magic Chef B31FK-7X-ON Range - F/s Std Gas
Magic Chef B31FK-92W Range - F/s Std Gas
Magic Chef B31FK-92X-ON Range - F/s Std Gas
Magic Chef B31FN-2KW Range - F/s Std Gas
Magic Chef B31FN-2KX-DD Range - F/s Std Gas
Magic Chef B31FN-2KX-ON Range - F/s Std Gas
Magic Chef B31FN-2W Range - F/s Std Gas
Magic Chef B31FN-2X-DD Range - F/s Std Gas
Magic Chef B31FN-2X-ON Range - F/s Std Gas
Magic Chef B31FN-3KW Range - F/s Std Gas
Magic Chef B31FN-3KX-ON Range - F/s Std Gas
Magic Chef B31FN-3W Range - F/s Std Gas
Magic Chef B31FN-3X-ON Range - F/s Std Gas
Magic Chef B31FN-7 Range - F/s Std Gas
Magic Chef B31FN-7W Range - F/s Std Gas
Magic Chef B31FN-7X-ON Range - F/s Std Gas
Magic Chef B31FN-92W Range - F/s Std Gas
Magic Chef B31FN-92X-DD Range - F/s Std Gas
Magic Chef B31FN-92X-ON Range - F/s Std Gas
Magic Chef B31FS-2KW Range - F/s Std Gas
Magic Chef B31FS-2KX-DD Range - F/s Std Gas
Magic Chef B31FS-2KX-ON Range - F/s Std Gas
Magic Chef B31FS-2W Range - F/s Std Gas
Magic Chef B31FS-2X-DD Range - F/s Std Gas
Magic Chef B31FS-2X-ON Range - F/s Std Gas
Magic Chef B31FS-3KW Range - F/s Std Gas
Magic Chef B31FS-3KX-ON Range - F/s Std Gas
Magic Chef B31FS-7 Range - F/s Std Gas
Magic Chef B31FY-2KW Range - F/s Std Gas
Magic Chef B31FY-2KX-DD Range - F/s Std Gas
Magic Chef B31FY-2KX-ON Range - F/s Std Gas
Magic Chef B31FY-2W Range - F/s Std Gas
Magic Chef B31FY-2X-DD Range - F/s Std Gas
Magic Chef B31FY-3KW Range - F/s Std Gas
Magic Chef B31FY-3KX-ON Range - F/s Std Gas
Magic Chef B31FY-3X-ON Range - F/s Std Gas
Magic Chef B31FY-7 Range - F/s Std Gas
Magic Chef B31FY-7W Range - F/s Std Gas
Magic Chef B31FY-7X-ON Range - F/s Std Gas
Magic Chef B31FY-92W Range - F/s Std Gas
Magic Chef B31FY-92X-ON Range - F/s Std Gas
Magic Chef B31HA-3KX-ON Range - F/s Std Gas
Magic Chef B31HN-3KX-ON Range - F/s Std Gas
Magic Chef B34FA-2CKW Range - S/c F/s Gas
Magic Chef B34FA-2CKXW-DD Range - S/c F/s Gas
Magic Chef B34FA-2CKXW-ON Range - S/c F/s Gas
Magic Chef B34FA-3EKXW-ON Range - S/c F/s Gas
Magic Chef B34FA-4CKXW Range - S/c F/s Gas
Magic Chef B34FA-4EKXW Range - S/c F/s Gas
Magic Chef B34FA-92CKW Range - S/c F/s Gas
Magic Chef B34FA-92CKXW-ON Range - S/c F/s Gas
Magic Chef B34FB-2CKXW-ON Range - S/c F/s Gas
Magic Chef B34FB-3EKXW-ON Range - S/c F/s Gas
Magic Chef B34FN-2CKW Range - S/c F/s Gas
Magic Chef B34FN-2CKXW-DD Range - S/c F/s Gas
Magic Chef B34FN-2CKXW-ON Range - S/c F/s Gas
Magic Chef B34FN-3EKXW-ON Range - S/c F/s Gas
Magic Chef B34FN-4CKXW Range - S/c F/s Gas
Magic Chef B34FN-4EKXW Range - S/c F/s Gas
Magic Chef B34FN-92CKW Range - S/c F/s Gas
Magic Chef B34FN-92CKXW-ON Range - S/c F/s Gas
Magic Chef B34GA-2CKW Range - S/c F/s Gas
Magic Chef B34GA-2CKXW-DD Range - S/c F/s Gas
Magic Chef B34GA-2CKXW-ON Range - S/c F/s Gas
Magic Chef B34GA-3EKXW-ON Range - S/c F/s Gas
Magic Chef B34GA-4EKXW Range - S/c F/s Gas
Magic Chef B34GA-92CKXW-ON Range - S/c F/s Gas
Magic Chef B34GB-3EKXW-ON Range - S/c F/s Gas
Magic Chef B34GN-2CKW Range - S/c F/s Gas
Magic Chef B34GN-2CKXW-DD Range - S/c F/s Gas
Magic Chef B34GN-2CKXW-ON Range - S/c F/s Gas
Magic Chef B34GN-3EKXW-ON Range - S/c F/s Gas
Magic Chef B34GN-4EKXW Range - S/c F/s Gas
Magic Chef B34GN-92CKW Range - S/c F/s Gas
Magic Chef B34GN-92CKXW-ON Range - S/c F/s Gas
Magic Chef B34HA-2CKXW-DD Range - S/c F/s Gas
Magic Chef B34HA-2CKXW-ON Range - S/c F/s Gas
Magic Chef B34HA-3TKX-ON Range - S/c F/s Gas
Magic Chef B34HA-3TKXW-ON Range - S/c F/s Gas
Magic Chef B34HA-5TKXW Range - S/c F/s Gas
Magic Chef B34HN-2CKXW-DD Range - S/c F/s Gas
Magic Chef B34HN-2CKXW-ON Range - S/c F/s Gas
Magic Chef B34HN-3TKX-ON Range - S/c F/s Gas
Magic Chef B34HN-3TKXW-ON Range - S/c F/s Gas
Magic Chef B35H-92X-DGI Range - F/s Std Ele
Magic Chef B35HA-2CX-ON Range - F/s Std Ele
Magic Chef B35HA-3EX-ON Range - F/s Std Ele
Magic Chef B35HA-92X-DGI Range - F/s Std Ele
Magic Chef B35HA-92X-ON Range - F/s Std Ele
Magic Chef B35HN-2CX-ON Range - F/s Std Ele
Magic Chef B35HN-3EX-ON Range - F/s Std Ele
Magic Chef B35HN-92W-EV Range - F/s Std Ele
  #2 (permalink)
Old 03-30-2009, 08:24 AM
Junior Member
Default
With a voltmeter attached to the freezer/evaporator fan connection on the control board and with the door open switch taped down, I was able to catch the fan not spinning while 13V was being supplied. At this point, I could spin the fan and occasionally get it spinning again.
I wasn't able to find a manual on the Bosch, but there is a Daewoo model that is pretty close. The diags and cycles seem to be the same http://www.daewoo.cl/sta-info/manuals/refrig/FRS-U20BCI_U21GAI.pdf
  #3 (permalink)
Old 03-30-2009, 01:35 PM
woodchuckie woodchuckie is offline
Hardcore DIY'er
APP Volunteer
woodchuckie is on a distinguished road
Default
I would replace the fan if I had to spin it to get it started. The condenser fan underneath and the evaporator fan runs when the compressor runs.
  #4 (permalink)
Old 04-08-2009, 01:15 PM
Junior Member
Default Followup
Ordered the fan motor through Bosch (cheapest), Unfortunately, AppliancePartsPros.com doesn't stock the Bosch Fridge parts yet. And replacing the motor resolved all the issues.
The Bosch ice maker is unique from traditional American ice makers. It uses a sensor in the back of the ice tray to detect when it's frozen and then cycles the ice by fliping and flexing the tray. No motorized timer, no heating element to free ice from tray or fingers to displace the ice. This icemaker will produce ice as fast as it is freezes.
I beleive my fan motor had been failing for some time. Over time the frequence that the motor wouldn't start increased and ice production eventually stopped. In addition, I noticed ice cubes clumped and frozen together. I didn't realize it at the time, but this foreshdowed that the freezer was periodicaly warming and as the motor would work the ice would refreeze. During all this time the lower portion of the freezer was at 0F and the Refrigerator maintaned 32F.
Thanks to woodchuckie and other experts for the help.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Temperature sensor problem stevetra Washer Repair 3 03-03-2009 02:57 PM
Viking oven temperature problem bob_serio Oven Repair (including Ranges and Cooktops) 0 01-10-2009 01:28 AM
temperature problem wparker824 Oven Repair (including Ranges and Cooktops) 0 12-30-2008 11:14 AM
Temperature Control Problem david mrak Refrigerator & Freezer Repair 11 12-15-2008 10:45 AM
Oven Temperature Problem Richard Summer Oven Repair (including Ranges and Cooktops) 5 09-29-2008 01:57 PM
