Discuss
Actuator replacement
 in
Refrigerator & Freezer Repair
The Actuator broke (that's the pad in the water dispenser that you press your glass against to get water)
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Actuator replacement
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 11-24-2007, 06:51 AM
Green14825 Green14825 is offline
Junior Member
Green14825 is on a distinguished road
Default Actuator replacement
Model Number: 241685703   Brand: Frigidaire   Age: 1 - 5 years
The Actuator broke (that's the pad in the water dispenser that you press your glass against to get water) in my double-sided Frigidaire (model: PLHS67EGSB1). I successfully purchased the replacement part, but have no idea on how to replace it. The part came with no instructions on how to do so. I'm not afraid to attempt the replacement, but I'm admittedly an extreme novice in this area.
I don't see where I can remove the front black dispensing area... it doesn't look like it'll fit over the broken actuator. And when I open the freezer door, I don't see where I can access that part of the dispenser without removing the inside of the door. So, before I start tearing my freezer apart, I'm seeking help from anyone who can help to replace this rather small part.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-25-2007, 07:00 AM
jumptrout51 jumptrout51 is offline
Expert
APP Volunteer
jumptrout51 is on a distinguished road
Default
It all replaces and accessess from the front. The black cover is attached by plastic clips. Most snap forward and then raise panel towards top of machine in a sliding motion.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
replacing the Actuator on my Frigdaire christopher0077 Refrigerator & Freezer Repair 0 08-10-2007 01:27 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
