ntjake
#1 Posted : Saturday, March 28, 2009 11:52:23 AM(UTC)
ntjake
both compartments warm in my side-by-side Frigidaire....I had the Hmmmm "Click" going on with the starter relay by the compressor.....so I replaced starter relay. All was good for a couple hours, then both refrigerator and freezer got warm again. After unplugging the unit for 24 hours, it would work for maybe an hour or two, then would get warm and Hmm Click started again. Top of compressor warm/hot to the touch.
Anything I can do short of replacing the compressor or scrapping the unit? It's 6 years old.
#2 Posted : Saturday, March 28, 2009 4:23:59 PM(UTC)
Here is a wiring diagram
ftp://ftp.electrolux-na.com/Pr...F/Anderson/240389607.pdf
Check the voltage at the plug.
Check the voltage at the compressor.
Make sure the condenser fan is running and blowing properly.
Make sure the condenser coils are clean.
The wiring diagram hints that there are alternate wiring set ups at the compressor. Check to see if you have a separate overload. Compressors usually have to get very hot before the thermal cutout trips.
ntjake
#3 Posted : Saturday, March 28, 2009 4:45:25 PM(UTC)
ntjake
Thanks for the quick reply. Not quite sure what you mean by 'check to see if there is a separate overload'...can you elaborate? It was very difficult to even get my hands by the compressor enough to replace the starter relay....so I'm not sure what I can do here.
Also, condenser fan is working just fine, and coils are clean.
#4 Posted : Saturday, March 28, 2009 5:22:28 PM(UTC)
Here is a good site with general info
http://www.applianceaid.com/refrigerator.html
Check out #3
ntjake
#5 Posted : Saturday, March 28, 2009 7:01:39 PM(UTC)
ntjake
I appreciate the response. What am I even looking for here? If I already replaced the starter...do you know what the other possible problems are?
#6 Posted : Sunday, March 29, 2009 2:01:00 AM(UTC)
Some units have the compressor temperature overload as a separate device, often a round disk. Check out the pictures at the bottom of #3.
It may also be built in to your PTC start relay.
I assume that this was happening every couple of minutes originally.
Compressor was trying to start but would not.
The unit did cool down so you know that the compressor will run and the freezer evaporator coils are working.
You said the compressor gets warm/hot and then it will not start. The compressor has a thermal overload but usually the compressor must be hot for this to open and you said warm so perhaps the thermal overload is tripping too low a temperature. When it is hot and will not run check the temperature of your PTC start relay see if it is very hot.
Check the compressor windings with a meter.
Check it when the unit is cold. Then let it heat up till it does not work and check it again.
The below links should help:
http://www.applianceaid.com/refrigerator.html#clicking
Refrigerator Repair Guide: How To Test the Compressor Motor - ACME HOW TO.com
#7 Posted : Sunday, March 29, 2009 8:47:42 AM(UTC)
Your compressor may have a internal varnish build up that can be fixed by injecting Supco 88 cleaner, but it has to be done by a pro.
