Discuss
Whirlpool Icemaker - no water
 in
Refrigerator & Freezer Repair
I have replaced the icemaker in my refrigerator, and am not getting water to the maker. Original problem was that
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Whirlpool Icemaker - no water
  #1 (permalink)
Old 03-28-2009, 06:00 AM
Junior Member
fixit54 is on a distinguished road
Default Whirlpool Icemaker - no water
Model Number: ED25DQXDW02 - Frigde   Brand: Whirlpool   Age: More than 10 years
I have replaced the icemaker in my refrigerator, and am not getting water to the maker. Original problem was that water was pouring into icemaker(fast) and not stopping, running out onto floor. Assumed it was icemaker not stopping water, but when I installed new unit... no water. I have checked the fill tube from back of unit into freezer and there is no frozen ice. There is not any water in tube from valve to the back of the unit. I still get water from the water dispenser in the door. Don't know what to check next
Ads By Google
Related Models
Whirlpool ED25DQXDW04
Whirlpool ED25DQXDW05
Whirlpool ED25DQXDW06
Whirlpool ED25DQXVF00
Whirlpool ED25DQXVF01
Whirlpool ED25DQXVF02
Whirlpool ED25DQXVF03
Whirlpool ED25DQXVF04
Whirlpool ED25DQXVF05
Whirlpool ED25DQXVF06
Whirlpool ED25DQXVF07
Whirlpool ED25DQXVG00
Whirlpool ED25DQXVG01
Whirlpool ED25DQXVG02
Whirlpool ED25DQXVG03
Whirlpool ED25DQXVG04
Whirlpool ED25DQXVG05
Whirlpool ED25DQXVG06
Whirlpool ED25DQXVG07
Whirlpool ED25DQXVM00
Whirlpool ED25DQXVM01
Whirlpool ED25DQXVM02
Whirlpool ED25DQXVM03
Whirlpool ED25DQXVM04
Whirlpool ED25DQXVM05
Whirlpool ED25DQXVM06
Whirlpool ED25DQXVM07
Whirlpool ED25DQXVN00
Whirlpool ED25DQXVN01
Whirlpool ED25DQXVN02
Whirlpool ED25DQXVN03
Whirlpool ED25DQXVN04
Whirlpool ED25DQXVN05
Whirlpool ED25DQXVN06
Whirlpool ED25DQXVN07
Whirlpool ED25DQXVP00
Whirlpool ED25DQXVP01
Whirlpool ED25DQXVP02
Whirlpool ED25DQXVP03
Whirlpool ED25DQXVP04
Whirlpool ED25DQXVS00
Whirlpool ED25DQXVS01
Whirlpool ED25DQXVW00
Whirlpool ED25DQXVW01
Whirlpool ED25DQXVW02
Whirlpool ED25DQXVW03
Whirlpool ED25DQXVW04
Whirlpool ED25DQXVW05
Whirlpool ED25DQXVW06
Whirlpool ED25DQXVW07
Whirlpool ED25DQXWN00
Whirlpool ED25DQXWW00
Whirlpool ED25DQXXN00
Whirlpool ED25DQXYN00
Whirlpool ED25DQXYN01
Whirlpool ED25DQXYN02
Whirlpool ED25DQXYW00
Whirlpool ED25DQXYW01
Whirlpool ED25DSXDB00
Whirlpool ED25DSXDB01
Whirlpool ED25DSXDB03
Whirlpool ED25DSXDB05
Whirlpool ED25DSXDN00
Whirlpool ED25DSXDN01
Whirlpool ED25DSXDN03
Whirlpool ED25DSXDN05
Whirlpool ED25DSXDW00
Whirlpool ED25DSXDW01
Whirlpool ED25DSXDW03
Whirlpool ED25DSXDW05
Whirlpool ED25DWXTF00
Whirlpool ED25DWXTF01
Whirlpool ED25DWXTF02
Whirlpool ED25DWXTF03
Whirlpool ED25DWXTF04
Whirlpool ED25DWXTF05
Whirlpool ED25DWXTG00
Whirlpool ED25DWXTG01
Whirlpool ED25DWXTG02
Whirlpool ED25DWXTG03
Whirlpool ED25DWXTG04
Whirlpool ED25DWXTG05
Whirlpool ED25DWXTM00
Whirlpool ED25DWXTM01
Whirlpool ED25DWXTM02
Whirlpool ED25DWXTM03
Whirlpool ED25DWXTM04
Whirlpool ED25DWXTM05
Whirlpool ED25DWXTN00
Whirlpool ED25DWXTN01
Whirlpool ED25DWXTN02
Whirlpool ED25DWXTN03
Whirlpool ED25DWXTN04
Whirlpool ED25DWXTN05
Whirlpool ED25DWXTW00
Whirlpool ED25DWXTW01
Whirlpool ED25DWXTW02
Whirlpool ED25DWXTW03
Whirlpool ED25DWXTW04
Whirlpool ED25DWXTW05
Whirlpool ED25DWXVF00
Whirlpool ED25DWXVG00
Whirlpool ED25DWXVM00
Whirlpool ED25DWXVN00
Whirlpool ED25DWXVW00
Whirlpool ED25EMXPWR0
Whirlpool ED25EMXPWR1
Whirlpool ED25GWXEN00
Whirlpool ED25GWXEW00
Whirlpool ED25GWXFW01
Whirlpool ED25GWXWN10
Whirlpool ED25GWXWW10
Whirlpool ED25GWXXN00
Whirlpool ED25GWXXW00
Whirlpool ED25GWXZN00
Whirlpool ED25GWXZN01
Whirlpool ED25GWXZW00
Whirlpool ED25GWXZW01
Whirlpool ED25LFXGB00
Whirlpool ED25LFXGN00
  #2 (permalink)
Old 03-28-2009, 06:04 AM
Junior Member
Default
Also, I did verify that the unit has power and is cycling.
  #3 (permalink)
Old 03-28-2009, 06:30 AM
Hardcore DIY'er
APP Volunteer
woodchuckie is on a distinguished road
Default
Try swapping the wires on the dual water inlet valve on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
  #4 (permalink)
Old 03-28-2009, 07:51 AM
Junior Member
Default
The 2 plugs are different sizes, was able to swap 1 of them....Now when I press for water, there is no power, press icemaker and it tries to dispense. After it dispenses I hear a sound that sounds like water flowing, but it is not flowing into the icemaker, sounds like it is in the door.
  #5 (permalink)
Old 03-28-2009, 08:04 AM
Junior Member
Default
I just switched the 2 plugs back, and the water dispenser does not work. No sound from it. Does it need to cycle for a while?
Ok, I had turned off water, then forgotten to turn water back on.
Now when I press ice dispenser, I get a puddle of water on the floor did not see origin.(water dispenser dispensing and overflowing)
  #6 (permalink)
Old 03-28-2009, 08:35 AM
Hardcore DIY'er
APP Volunteer
Default
Disconnect the line coming out of the water inlet valve on the back and see if it keeps leaking there. May be sediment in the line preventing the valve from closing.
  #7 (permalink)
Old 03-28-2009, 08:41 AM
Junior Member
Default
No leaking from the back, I think when I cycled the icemaker, with plugs switched, it sent water to dispenser. there is no water in the line between the valve and the entry to the freezer at top to unit. Seems like the valve is not opening. Considering that before I replaced icemaker, it was stuck open(had to shut off all water to fridge), it sounds like it may be the valve. Is there a way to "clean it", or to test it? Water lines are diff sizes so can't swap them.
  #8 (permalink)
Old 03-28-2009, 01:28 PM
Junior Member
Default
With the info I hade, I decided to replace the inlet/solenoid unit and that fixed the problem. Water flowed to icemaker before I finished putting screws back!!!
Thanks woodchukie!!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool icemaker getting no water(tube is freezihg) DRI Refrigerator & Freezer Repair 2 10-04-2009 04:26 AM
Whirlpool icemaker getting no water(tube is freezihg) DRI Refrigerator & Freezer Repair 0 10-03-2009 01:25 PM
whirlpool side by, no water to icemaker MarkUSAF Refrigerator & Freezer Repair 0 10-03-2009 12:12 PM
whirlpool icemaker not getting water Edwardo Refrigerator & Freezer Repair 1 05-01-2008 06:01 PM
