Discuss
kenmore side by side refrigerator
 in
Refrigerator & Freezer Repair
The panel that separates the freezer from the refrigerator was burning up. Just on the outside panel when I open
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » kenmore side by side refrigerator
  #1 (permalink)
Old 08-05-2011, 08:25 AM
Junior Member
djurickovic is on a distinguished road
Default kenmore side by side refrigerator
Brand: Kenmore   Age: 5 - 10 years
The panel that separates the freezer from the refrigerator was burning up. Just on the outside panel when I open the doors. What is causing this?
Ads By Google
  #2 (permalink)
Old 08-05-2011, 08:46 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
That panel or strip between the two compartments is called a "mullion" strip. It is supposed to be warm but not HOT.
When it does get hot, it is usually due to a clogged condenser coil and a condenser fan motor running slow or not at all.
Depending on your model number, you will need to access the back of the refrigerator, remove the rear lower access panel and check and clean all the lint, dust , and debris.
Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 08-05-2011, 08:49 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Often it is dirty condenser coils or the condenser/compressor fan is not running (poor air circulation).
Also some unit have an eco/energy switch. This turns a heater on/off which is between the sections and prevents condensation in high humidity conditions. If your unit has one turn it off.
__________________
  #4 (permalink)
Old 08-07-2011, 03:35 PM
Junior Member
airwings is on a distinguished road
Default Mullion strip is too warm
It's quite likely that your condensor fan is not working. Check it for continuity with a multimeter set at ohms X10. Unplug your fridge and pull off the terminal to the fan (back side, bottom of fridge). Touch the two outer posts on the fan with the multimeter. It should read somewhere between 0 and infinity. If it doesn't, the fan is bad. If it's not this, you will need an electrical schematic, and identify the switches, relays, or whatever activates the fan. Good luck.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore elete side by side refrigerator icemaker turkey_25 Refrigerator & Freezer Repair 0 08-01-2011 01:40 PM
Kenmore Side by Side 363 7512413 Freezer and Refrigerator won't freeze and cool. SandraKUnkel Refrigerator & Freezer Repair 0 07-24-2010 09:15 AM
KENMORE SIDE BY SIDE Refrigerator FREEZER NOT FREEZING howiey@yahoo.com Refrigerator & Freezer Repair 1 03-25-2010 05:34 AM
How to take the faceplate of off kenmore side by side refrigerator jessica0833 Refrigerator & Freezer Repair 9 09-05-2009 04:03 PM
Kenmore side by side refrigerator/freezer hdmays619 Refrigerator & Freezer Repair 1 04-03-2008 01:56 PM
