| » Freezer Cold,But refrig warm |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: FRS6R4EB9 Brand: Frigidaire Age: Less than 1 year
Problems with Frigidaire FRS6R4E Side by Side Refrigerator. Freezer cold, but frig not blowing any cool or cold air to refrig. I checked the back for frozen lines, dust, and anything unusual. Everything looks fine. I took the plastics rail(inside refrig) off the check to see if the damper open and working. It opens when shutting off and noticed it opened for air flow. I discovered no cold air being transfer from freezer to refig. I checked the bottom inside refrig, and noticed more vent hole. No air blowing, but noticed the lines inside froze up with ice. Need help!
first of all if less than a year old call a service company for repair becuase it is under first year warranty. If you want to know how to check this one you need to see if the fan in the freezer is running blowing cold air up from the evaporator ( it is behind the freezer wall) if it is click the refig side light switch five times in five seconds (this will put it in defrost mode)take you amp meter wrap it around the heater wire and see if you are reading 3-5 amps if not write back (a bad defrost circuit)
__________________
J&D Appliance Repair Serving Pendleton County, Kentucky and Surrounding Areas |
| Display Modes | |
| GE Refrigerator is warm freezer is cold !! | Steve705 | Refrigerator & Freezer Repair | 1 | 10-07-2007 12:24 PM |
| Fridge & Freezer Cycle Cold To Warm Back To Cold | terkel | Refrigerator & Freezer Repair | 1 | 09-25-2007 02:58 AM |
| refrig not blowing cold but freezer fine | chaikid | Refrigerator & Freezer Repair | 1 | 09-11-2007 07:14 PM |
| Freezer blows cool but not freezing and refrig is warm | Angelicas | Refrigerator & Freezer Repair | 2 | 08-08-2007 08:06 PM |
| Refrig works but freezer is not running cold enough | Bill Tagatz | Refrigerator & Freezer Repair | 1 | 08-01-2007 05:43 AM |
