My ice maker is working fine except the frig was in storage for awhile and the auger got rusty on the surface I guess because it wasnt dried off before going to storage. Now when the ice falls it has rust on it and no one wants that in their glass.
I am wondering if I should sand the rust off the surface or replace the auger. If I replace the auger would it be very difficult since I am not that good with fine detail. looking at it I cannot tell where the screws are. Can you give me some advise on how to take the rusty one out and put a new one in.
Thank you very much
Diann
Originally Posted by: ddillingham My ice maker is working fine except the frig was in storage for awhile and the auger got rusty on the surface I guess because it wasnt dried off before going to storage. Now when the ice falls it has rust on it and no one wants that in their glass.
Thank you very much
Diann I had the same problem woth my GE, and it was very easy to repair. Only 4 screws which I marked to ensure they went back correctly and I sanded the rust off with steel wool and it has been fine for almost 3 years now. My suggestion is mark everything with a sharpee pen, even place arrows on things. Good luck...
