| » coil freeze up |
Model Number: psh23pgra Brand: GE Age: 1 - 5 years
changed sensors in freezer section & 'frige section, changed main board, all at recommondations by other blogs, still coil behind produce bin still ices up completely every 2 weeks. i see a sensor mounted under the coil after I defrost it, can this be the problem?? HELP
Related Models |
did you check the heater at the bottom of the coil (evaporator)
__________________
J&D Appliance Repair Serving Pendleton County, Kentucky and Surrounding Areas |
let,s start over, you say the coils are iceing up, does this mean there ice or snow? if there ice this may not be a defrosting problem it may be a drain problem ,on the model # i did not see a drain trough heater make sure there is no service flashes on this problem . Make sure the drain is completely clear. Then we go from there.
__________________
| Display Modes | |
| SubZero Frige not cold, but freeze works | wasmis | Refrigerator & Freezer Repair | 3 | 05-24-2008 11:05 PM |
| no cold or freeze | tms | Refrigerator & Freezer Repair | 2 | 11-07-2007 09:31 AM |
| Gas Valve Solenoid Coil | Teewaddy | Dryer Repair | 5 | 10-25-2007 05:45 PM |
| whirlpool electric coil cooktop | jaffej | Oven Repair (including Ranges and Cooktops) | 0 | 07-25-2007 10:06 AM |
| freezer coil freezing | trey1122 | Refrigerator & Freezer Repair | 1 | 07-20-2007 06:27 PM |
