Hi, I have a sears Kenmore Elite refrigerator that recently started cycling on and off, and also makes a loud click and a buzzing noise when the compressor turns on.
I pulled it away from the wall and cleaned everything really good. I did notice that the compressor was hot.
sounds like your start device and/or overload relay may have fried
If the compressor is very hot, you may have a shorted compressor winding. An amprobe would confirm.
Originally Posted by: richappy If the compressor is very hot, you may have a shorted compressor winding. An amprobe would confirm. I replaced the start relay, and it did not fix the problem. Just bought a new samsung fridge four door model. Stainless Steel. I hope it lasts longer than the Sears trio stainless steel.
