Amana Refrigerator-Freezer MN ARB8057CSR, MFG NO PARB8057CS3 No water to ice maker or to water dispenser. Pressing switch for water dispenser causes whirring sound, no water. Water supply to valve is OK. Filter is OK. Suspect primary water valve, but should I replace both valves? Does the sound tell me anything? Thanks in advance.
