benecia
#1 Posted : Tuesday, March 24, 2009 1:36:22 PM(UTC)
benecia
The interior light just stopped working a few days ago.
I replaced the 40 watt bulb - but it still does not work. I even tested the 40 watt bulb in another appliance - and the bulb worked fine.
I don't see where much else is easily accessible. There is some wiring to the unit that holds the light bulb - but that disappears underneath the covering. There is also the switch - that turns on the light when the door is open and shut - I do not see how to easily access this either?
Is there anything else that I can do short of having to calling a repair man or throwing the refridgerator out. I am very decent in being able to do home repairs - but I don't see any choices to get the light working again.
Thanking you in advance.
Drags1998
#2 Posted : Tuesday, March 24, 2009 1:39:44 PM(UTC)
Drags1998
Put on a GLOVE and TIGHTEN the bulb!!!! The seal around the bulb is grabbing the bulb before you get it tight enough.:)
benecia
#3 Posted : Tuesday, March 24, 2009 2:02:59 PM(UTC)
benecia
Thank you - I put on a rubber glove and tightened as much as I could - but still does not work. ANy tighter and the bulb will break.
ANy other ideas !
woodchuckie
#4 Posted : Tuesday, March 24, 2009 8:40:51 PM(UTC)
woodchuckie
You should be able to pry, pop the switch out to bypass it to see if that's the problem.
