THe dispenser broke off and the white plastic was jammed in. I removed the panel and got the plastic out, but when I did the metal connecting the pink outlet with wires broke off from the switch limit. I ordered switch limit (AP4014023) from appliancepartspros.com. The metal connectors look like they go into the pin outlets. But it appears the metal from the old switch limit broke off and is stuck in the pink outlet connected to the wires. How do I get the metal out and can I just connect the new switch limit to the pink outlet with wires? Any advice? Thanks!
