No Ice. Installed new valve, still no ice. Repair manual says the normal position of the ejector blades should be 2 o'clock. This one at 9 o'clock. swithches and thermostat checked ok. Manual says motor should have "significant continuity." this one about 500 Ohms. Also, when I removed the gear from the ejector blade and tried to rotate the motor, it does not turn by hand at all. Bad motor? If so, when I replace it how do I make sure timing is correct when I put gears back on? Thank You
Jack
