Discuss
Compressor Run Condenser Fan Does Not
 in
Refrigerator & Freezer Repair
The compressor properly cycles on and off. The condenser fan does not start when the compressor starts. If I spin
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Compressor Run Condenser Fan Does Not
  #1 (permalink)
Old 07-29-2011, 10:08 AM
Junior Member
CGParker is on a distinguished road
Default Compressor Run Condenser Fan Does Not
Model Number: BX21TW   Brand: Amana   Age: More than 10 years
The compressor properly cycles on and off. The condenser fan does not start when the compressor starts. If I spin the condenser fan after the compressor starts, then the condenser fan will continue spinning until the compressor shuts off. This symptom is consistent.
I removed the condenser fan (AP3120994) in order to test its operation. The condenser fan is an 2 watt 115 volt ac motor. When the condenser fan is connected to a power source, the fan starts immediately and continues to run until power is removed. Operation outside the refrigerator seems normal.
The compressor/condenser fan control includes an overload device, PTC relay (AP 2966871) and capacitor (AP 313171e). I assume the PTC relay supports the compressor startup. I am not sure if the capacitor supports the compressor and/or the condenser fan. The circuit diagram refers only to the capacitor (neither start nor run) with the comment "as required on some models".
Is there a way to isolate the problem to the condenser fan or capacitor or should I replace both or have I missed the problem entirely?
Thanks in advance for any help provided, CGParker
Related Models
Amana BX21TW REF - BOTTOM MOUNTS
Amana BX21V1C REF - BOTTOM MOUNTS
Amana BX21V1E REF - BOTTOM MOUNTS
Amana BX21V1W REF - BOTTOM MOUNTS
Amana BX21V2C REF - BOTTOM MOUNTS
Amana BX21V2E REF - BOTTOM MOUNTS
Amana BX21V2W REF - BOTTOM MOUNTS
Amana BX21VC REF - BOTTOM MOUNTS
Amana BX21VE REF - BOTTOM MOUNTS
Amana BX21VL REF - BOTTOM MOUNTS
Amana BX21VW REF - BOTTOM MOUNTS
Amana BX22A2E REF - BOTTOM MOUNTS
Amana BX22A2L REF - BOTTOM MOUNTS
Amana BX22A2W REF - BOTTOM MOUNTS
Amana BX22A5L REF - BOTTOM MOUNTS
Amana BX22A5W REF - BOTTOM MOUNTS
Amana BX22R3E REF - BOTTOM MOUNTS
Amana BX22R3L REF - BOTTOM MOUNTS
Amana BX22R3W REF - BOTTOM MOUNTS
Amana BX22RE REF - BOTTOM MOUNTS
Amana BX22RL REF - BOTTOM MOUNTS
Amana BX22RW REF - BOTTOM MOUNTS
Amana BX22S5E REF - BOTTOM MOUNTS
Amana BX22S5L REF - BOTTOM MOUNTS
Amana BX22S5W REF - BOTTOM MOUNTS
Amana BX22TE REF - BOTTOM MOUNTS
Amana BX22TL REF - BOTTOM MOUNTS
Amana BX22TW REF - BOTTOM MOUNTS
Amana BX518VE REF - BOTTOM MOUNTS
Amana BX518VW REF - BOTTOM MOUNTS
Amana BX521VCPER REF - BOTTOM MOUNTS
Amana BX521VCPSR REF - BOTTOM MOUNTS
Amana BX521VCPWR REF - BOTTOM MOUNTS
Amana BX521VE REF - BOTTOM MOUNTS
Amana BX521VW REF - BOTTOM MOUNTS
Amana BXF19TL REF - BOTTOM MOUNTS
Amana BXF19TW REF - BOTTOM MOUNTS
Amana BXI21VE REF - BOTTOM MOUNTS
Amana BXI21VL REF - BOTTOM MOUNTS
Amana BXI21VW REF - BOTTOM MOUNTS
Amana BXI22S5E REF - BOTTOM MOUNTS
Amana BXI22S5L REF - BOTTOM MOUNTS
Amana BXI22S5W REF - BOTTOM MOUNTS
Whirlpool BYCCD3421W0 COMPACT ELECTRIC DYER
Whirlpool BYCCD3421W1 COMPACT ELECTRIC DRYER
Whirlpool BYCCD3421W2 COMPACT ELECTRIC DRYER
Whirlpool BYCCD3421W3 COMPACT ELECTRIC DRYER
Whirlpool BYCCD3921W0 ELECTRIC DRYER
Whirlpool BYCD3722W0 DRYERS
Whirlpool BYCD3722W1 ELECTRIC DRYER
Whirlpool BYCD3723W0 DRYERS
Whirlpool BYCD3723W1 GAS DRYER
Whirlpool BYCD3723W2 DRYER
Whirlpool BYCD4932W0 ELECTRIC DRYER
Whirlpool BYCD4933W0 GAS DRYER
Whirlpool BYCW4271W0 DIRECT-DRIVE WASHER
Whirlpool BYCW6292W0 WASHER
Whirlpool BYCWD6274W0 LAUNDRY COMBINATION UNITS
Whirlpool BYCWD6274W1 WASHER / DRYER COMBINATION UNIT
Whirlpool BYCWD6274W2 WASHER/DRYER COMBO
Whirlpool BYCWD6274W3 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool BYCWD6274W4 WASHER/DRYER LAUNDRY SYSTEM
Amana BZ20QE REF - BOTTOM MOUNTS
Amana BZ20QG REF - BOTTOM MOUNTS
Amana BZ20QL REF - BOTTOM MOUNTS
Amana BZ20QW REF - BOTTOM MOUNTS
Amana BZ20R REF - BOTTOM MOUNTS
Amana BZ20RE REF - BOTTOM MOUNTS
Amana BZ20RG REF - BOTTOM MOUNTS
Amana BZ20RL REF - BOTTOM MOUNTS
Amana BZ20RW REF - BOTTOM MOUNTS
Amana BZ22QE REF - BOTTOM MOUNTS
Amana BZ22QL REF - BOTTOM MOUNTS
Amana BZ22QW REF - BOTTOM MOUNTS
Amana BZ22R3E REF - BOTTOM MOUNTS
Amana BZ22R3L REF - BOTTOM MOUNTS
Amana BZ22R3W REF - BOTTOM MOUNTS
Amana BZ22R5L REF - BOTTOM MOUNTS
Amana BZ22R5W REF - BOTTOM MOUNTS
Amana BZ22RE REF - BOTTOM MOUNTS
  #2 (permalink)
Old 07-29-2011, 02:09 PM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Cg,
The overload, PTC relay and capacitor support the compressor and it's circuits. The condenser fan motor and the evaporator fan power and the 120 VAC supply to the overload device are a supply from the cold control.
I would have to think, you have a loose or weak connection at the wires to the condenser fan motor, you should check that first. Otherwise the fan motor would be bad.
Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 08-06-2011, 08:50 PM
Junior Member
Default
I did some cleaning and checking of the motor and the motor wire connectors. Removed the temporary fan and re-installed the original motor.
Had a momentary panic until the defrost timer allowed the compressor to run (thought I had destroyed the compressor operation).
The original fan is now operating correctly cycling on and off with the compressor. This may only be temporary, so I will monitor the operation for a while to see if it continues to run as it should.
CGParker
  #4 (permalink)
Old 08-08-2011, 06:32 AM
Senior Expert
Default
CGParker
CG,
Good Deal,
We'll keep an eye out for your next post, Hope all stays well.
__________________
Joe M. APP TEAM
  #5 (permalink)
Old 05-29-2015, 04:25 PM
Junior Member
spencer_ledlow is on a distinguished road
Default Same problem but led DS1 lights for about 3 seconds
There is no voltage across the starting cap and no sound like the motor wants to start.
  #6 (permalink)
Old 06-01-2015, 07:15 AM
Senior Expert
Default
Quote:
Spencer, There won't be any voltage across the capacitor, unless the motor is starting or running, and it would take a special meter to read.
Like all capacitors you can circuit check the component. Disconnect the wires from the capacitor, place your meter leads across the terminals on the capacitor. The meter should deflect towards a "closed" circuit then revert back to an "open" circuit. If the meter doesn't deflect or doesn't return to the "open" circuit, then the capacitor needs to be replaced.
When a capacitor fails, it's usually pretty obvious, They "blow up or out". If the capacitor checks proper, then you'll need to check for voltage to the overload and the overload circuit, then the start relay and compressor motor windings.
__________________
Joe M. APP TEAM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
power surge damaged power pack,replaced,compressor and condenser fan still not runnin shillion Refrigerator & Freezer Repair 0 11-16-2010 01:38 AM
condenser fan mfilosa3914 Refrigerator & Freezer Repair 2 05-09-2010 12:24 PM
freezer warm, clicking noise from compressor, compressor very hot sgtmajor58 Refrigerator & Freezer Repair 1 08-08-2009 06:57 PM
Condenser Fan khm Refrigerator & Freezer Repair 0 06-22-2009 08:25 PM
frig and freezer warm,clicking noisefrom compressor,compressor very hot tdot Refrigerator & Freezer Repair 4 04-02-2008 08:35 AM
