Discuss
Loose refrigerator door handle
 in
Refrigerator & Freezer Repair
The diagram of the refrigerator door is in the attached file I would like to tighten my refrigerator door handle
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Loose refrigerator door handle
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 11-22-2007, 08:12 AM
danek danek is offline
Junior Member
danek is on a distinguished road
Default Loose refrigerator door handle
Model Number: ED25DQ   Brand: Whirlpool   Age: More than 10 years
I would like to tighten my refrigerator door handle but can not find a way to get at the screws(#5) holding the handle holder(#12) to the door.
I have been able to remove the
trim end caps (#29);
handle / handle holder screws(#34)
But neither the trim or the handle is moving.
Any help you could give me would be much appreciated!
Last edited by danek : 11-22-2007 at 11:54 AM. Reason: diagram not available on link given originally
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-22-2007, 11:44 AM
Junior Member
Default corrected link for diagram
Reply removed and original post was edited.
(Sorry, I did not know how to edit my original post)
Last edited by danek : 11-22-2007 at 11:57 AM. Reason: diagram placed in original post.
  #3 (permalink)
Old 11-23-2007, 04:15 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
You will have to remove the entire inner door panel to get to these screws.
__________________
  #4 (permalink)
Old 11-23-2007, 07:50 AM
Junior Member
Thumbs up I did it!
Step by step for anyone else attempting this...
1)Remove the silver cap (#29) from the top of the white trim. Even though is might be pretty tight, I would suggest trying to rock it back with your thumbs before taking a tool to it. It is, after all only plastic.
Note: The trim(16) is secured to the trim track(28) by bumps in the trim. There are about 5 bumps on each side about 3 inches apart. These bumps are stagered on each side to make the removal a easier. (They are not right across from each other)
2)To start taking the white trim from the silver trim track insert a screwdriver in where the silver cap was, and gently pry the trim from the track. This should get the trim off the first few inches of the trim track.
3)I loosened the rest of the trim using a putty knife. I placed the end of the putty knife between the trim and the trim track in the lower section of the area I had already loosened and poped track out a little more, past the next nub. I then went to the other side of the track and repeated the process, altenating from side to side poping the trim out nub by nub.
This might sound like a long process, but in reality took less than 3 minutes even being very careful. After all, the trim is rather thin and can be bent or scraped somewhat easily.
4)Tighten screws on handle (#5)
5)Pop trim back in, starting on the bottom.
6)Replace silver caps.
If I can do this, you can too.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Microwave Door Handle weissjp Microwave Repair 7 08-13-2008 09:56 AM
Loose handle dougvegge Refrigerator & Freezer Repair 2 07-19-2008 10:40 AM
Door Handle Repair okorn31 Microwave Repair 1 11-20-2007 11:19 AM
Replace Door Handle btcsys Microwave Repair 1 11-09-2007 02:04 PM
loose oven door handle duck Oven Repair (including Ranges and Cooktops) 1 07-31-2007 06:04 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
