Register | FAQ's | New Posts | Today's Posts | Extras |
» GE Freezer won't make ice |
See inside of your appliance - diagrams and part photos for virtually every model.![]() powered by AppliancePartsPros.com |
![]() I get drinking water to the door w/o a problem and I checked the water line that goes to the freezer/refrigerator and it is fine. I'm not sure what it is called but the tube that goes through the rear freezer wall that empties water directly into the ice tray is totally frozen. I thawed and it and reinstalled it and it froze up again.
I hope that makes sense ![]() |
![]() The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure. |
![]() No leak as far as I can tell, but the entire tube that water drains from into the trays all the way through the rear wall that water comes in through is frozen solid. I'm not sure what usually keeps that from freezing. I guess that would be my issue.
Thanks |
![]() Hello,
My GE freezer isn't making ice. I took it apart and found that the tube that comes through the back of the freezer wall was frozen solid. No water could get in like that so it wasn't making any ice. That seemed to make sense so I thawed the tube and put it back together. Let the frezer cool and then turned the ice maker back on. I may have got a cube or two but no major ice. I checked it again and the tube is frozen again. What is causing this? Thanks[/quote] |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Freezer not cold enough to make ice | tomking | Refrigerator & Freezer Repair | 3 | 12-17-2009 06:34 PM |
is there a vacuum pump to make a whoosh sound in a freezer when the door is first clo | garen | Refrigerator & Freezer Repair | 2 | 05-23-2009 01:33 PM |
Fridge and Freezer make popping noise and not cool | kellytascon | Refrigerator & Freezer Repair | 4 | 10-29-2008 09:13 PM |
