Hello,
My son inadvertently left the freezer door cracked open for most of the day, and now my ice maker is not working. I have defrosted the entire refrigerator, and I have tested the inlet valve, and it is pumping water, however the water isn't coming into the ice tray. The LED light on the right side of the freezer is flashing intermittently. (flash-flash/1 sec. pause/flash-flash) It does that same pattern whether I hold down the flap on the left side of the door or not. What would be keeping the water from coming into the ice maker? I would appreciate some guidance!
hi i have a whirlpool gold side by side the ice maker stop making ice
