water jam
Icemaker itself seems to work fine. Makes ice anddumps it in tray.
Inlet water tube seems to freezes up. Put a new water valve on and have same problem. Ice will dump out of tray. Adjusted making the cubes smaller, but didn't seem to matter. Eventually it freezes up the fill tube then starts overflowing water into the freezer area. About ready to order a whole new icemaker, but afraid this will not fix it. Water does not leak by new water valve |
I would rather suggest you not order a new icemaker but you should ask for the technician because I had similar type of problem and it was solved by technician. :)
| All times are GMT -7. The time now is 10:33 AM. |
