| » Not holding temperature |
Model Number: PFS22SISBss Brand: GE Age: 1 - 5 years
Neither my fridge nor freezer will hold the correct temperature. The coils are not frozen over, but the condensor fan is spinning VERY slowly. Any thoughts?
I have a GE model PFS22MISBBB that had the same problem, there should be small panel with three screws holding it on, under it is the main control board. When I checked mine it had some burnt components in the upper right corner, after I replaced it the compressor fan started run properly. Has your fridge been making a clicking noise prior to it stopping cooling, if so you have more problems than just the fan. You may have a bad start/overload OTC relay also, I ordered one for mine and I'm waiting for it to arrive. Will let you know how it turns out.
Sorry for the slow update, Recieved the Overload/OTC relay. The install was very easy, make sure you remove the Capacitor from your old relay and re-use it on the new one. This fixed mine. Apparently the compressor fan failed and then the relay kept tripping (this must have been the clicking noise) until it broke.
| Display Modes | |
| oven not holding temperature | caberg23 | Oven Repair (including Ranges and Cooktops) | 0 | 05-18-2011 02:22 PM |
| Hotpoint oven not holding temperature | handyman52 | Oven Repair (including Ranges and Cooktops) | 1 | 12-13-2010 08:38 PM |
| Tub not holding water | grunt1 | Washer Repair | 3 | 11-01-2010 01:25 PM |
| GE Gas Range not holding temperature | dfriend | Oven Repair (including Ranges and Cooktops) | 2 | 02-23-2010 10:28 AM |
| Bosch Holding water | crackindale | Dishwasher Repair | 0 | 08-04-2009 07:35 AM |
