I want to replace the run cap on the above unit. Part # is AP2071964. It is a 12uF cap. My question is can I go to the local HVAC store and buy a 12uF cap for about $6 instead of having to order the exact replacement? Is there a design difference between a run cap and a start cap? The $6 cap is larger in physical size and is rated for up to 370 volts. Thanks for the help
