Looking for instructions to install the frame for the ice dispencer funnel. The funnel is on the outside of the door. The brand is LG. Thanks in advance.
funnel part # 3016JA2002M frame part # 3210JA0006S
Hello convincor. Here are the instructions from the manufacture for disassembling the dispenser. You will reverse the procedure to reinstall. Hope this helps. 1) Disconnect funnel and button assembly by pulling down and forward. 2) Remove display frame Assembly by making a gap between a display frame Assembly and funnel Assembly. with a balde screwdriver and pulling it forward. The cover dispenser is attached with a hook. 3) The Display Assembly can be connected by pressing the top of the dispenser cover and pushing it after separating the Display Frame from its housing. 4) Loosen four screws with a phillips screwdriver and pull the funnel Assembly to disconnect.
